Blower motor noise
Old Apr 2, 2023 | 03:30 PM
jls667's Avatar
jls667
Default Blower motor noise
The blower motor is sometimes making noise. I believe it is a sign the bearings are going. I replaced it only five years ago. Is this normal? The original one lasted 14 years.
Old Apr 2, 2023 | 03:39 PM
Roll the dice on used OEM would be my call
https://www.ebay.com/itm/313784154909
Old Apr 2, 2023 | 04:34 PM
Yamae's Avatar
Yamae
Isn't that a high pitched noise like an oscillation? Other than the bearing, there sometimes happen strange noise from the motor controller. It is high pitched and you even can hear it when the motor is running slow.
Old Apr 2, 2023 | 04:52 PM
LS430inDE.'s Avatar
LS430inDE.
Could it be debris or a leaf stuck down there and touching the fan? Try turning the fan speed to maximum for as long as you can tolerate, to try and free-up the debris (if it's physical debris). When was the last time you changed/checked your cabin filter?
Old Apr 9, 2023 | 11:40 AM
jls667's Avatar
jls667
The noise is not high pitched. It does go away when the fan is off. I tried raising the fan speed; the noise does not get worse.
Old Apr 10, 2023 | 07:26 AM
Yamae's Avatar
Yamae
That's what I worried about. Toyota/Lexus had complains from owners of LS400 and some other cars. Owners were claiming that strange noise could be heard from somewhere near the blower motor. It was found to be from the blower motor controller and Toyota/Lexus changed the design of the controller as is shown below.
The left side is the one before the counter measure and the right side is the countermeasured one to be quiet. But still there were some problems. LS430s were designed not to have noise problems but still there happens some. Yours may be so. It is not very easy to eliminate the magnetostrictive vibration.
Clayboy718
May 10, 2022 02:08 AM
Yamae
Sep 24, 2021 11:45 AM
tiglesias
Nov 8, 2020 07:15 PM
AVH1
Jan 26, 2020 10:31 AM
