(Advice/Help) 04 Ls430 with minor problems seeking wisdom.
MIlage: 188K
(First time buyer) a 19yr old who wanted a luxury boat. Looking for tips, tricks and any advice for the maintenance and mods I'll be doing over the given months when I find time. PLEASE LINK THREADS WITH INFORMATION IF POSSIBLE. Ive been looking around here for a little while before I made my purchase.
All Problems:
- BIGGEST CONCERN:
Codes P0171, P0174, C1201. My Dash is lit like a Christmas tree. Door lock actuator and sensor for smart key(Driver and right back door). Update: Ordering D Shaft motors.- Trunk Tail lights out/dimmed.
- Windshield fluid doesn't spray (Also the button for the stalk is gone) Probably failed motor.
- Steering wheel only tilts doesn't not go in or come out.
Tire low warning (Yes it has the needed air). I think it's connected to problem 1 but I'll list it here still.Cup holder broken along with slightly stuck armrest console (I believe it's just tightening the bolts up)Some stuck plastics (Glasses holder, rear seat mirrors. Will change as I find donors from yards). Would love links to places I can search for them online.Gas door assembly seems tampered and would like to see schematics for reinstall.Headlights very yellow.No idea when the timing belt was last checked. (Seems a fresh belt was put on before my ownership)
- Lip kit.
Android Head unit install+ amp and new sub.- Taking a crack at retro fitting Infinity Mirror Tail lights.
- (UNSURE) throttle controller or any power mods really
- Wheels/Suspension (Rims, bushings, Coils, etc.)
- Muffler delete + 3.5 tips
- Door speaker upgraded (Kicker 47KSC6504)
- Teyes CC3 2K Android Head unit kit
Miscellaneous:
- weather seals
- Door lock actuators
- Door handle sensors
- Front passenger window noise.
- O2 sensors out (Will put specific code up next time I check the car) It's got my dash looking like a Christmas tree.
- By new ones (denso or NGK brand ony) from Rockauto
- Door lock actuator and sensor for smart key (Driver and right back door)
- you will eventually have to replace all your door lock actuators. I replaced all mine on my 2004. Not hard, but very time consuming
- Tail lights out/dimmed. (Trunk lights, still driveable)
- NO idea
- probably will have to replace the stalk itself.
- Extremely common problem. its the motor in the steering column, a huge PITA to change out.
- Tire low warning (Yes it has the needed air)
- TPMS sensors inside the wheels need replacing
- Cup holder broken along with slightly stuck armrest console (I believe it's just tightening the bolts up)
- Common issue, find replacements in a junkyard
- Some stuck plastics (Glasses holder, rear seat mirrors.
- Gas door assembly seems tampered and would like to see schematics for reinstall.
- Headlights very yellow
- Polish or replace
- No idea when the timing belt was last checked.
- Make this your #1 priority to get it replaced. you should be doing this before speakers, etc.
Since you listed the mechanicals first I’m assuming those are priority, good call.
There has been one or two people who have fixed these taillights, but the consensus is just to hit a dismantler or eBay and get another. These LED boards weren’t meant to be serviceable.
The LS430 doesn’t use a normal TPMS system, it goes off rolling diameter differences, that’s about all I know. So make sure your tires are the same (or close enough) overall diameter and similar compound.
Headlights are easy enough to polish.
I redid my entire audio and made a thread on it. Not the most informative but should be kinda helpful.
Then made another thread on the box I built because I wasn’t happy with the standard box in the trunk setup.
My audio thread
I personally have seen 140Mph on my TomTom SatNav on the Autobahn and would have gone higher but my better half was having kittens in the passenger seat <LOL>
If you pop off the black lower trim panel right by the pedals, lay on your back and look up behind the dash, you can see it and its not terribly difficult to get to. It doesn't require the steering column covers behind the wheel to be removed either.
If I recall, I remember mine having 2 10mm bolts, and an electrical connector, and the it can just be swapped out.
Of course, mine is a 2002, and I'm not sure if they made any changes to the 2004 and up models....
Restored my headlights while attempting to let my MAF sensor and throttle body dry (only cleaned the front of it since I didn't have a new gasket on hand.)
Too a minute to start but she came back Alive. Plans are to change out all O2 sensors and fully clean or replace the throttle body. I believe that should fix codes PO171-4.
I was suggested to change out the lines going to the air box. Are these standard lines or something I'll have to scavenge for?
And finally I noticed this while hanging around my engine bay..... Does anyone know what this is supposed to connect too?
- NO idea
- Polish or replace
I have the lock actuators on order. Still need to see about the sensors.
I'll probably wait and see about the windshield wiper at the same time I'm replacing the tilt motor on the steering wheel.
I've seen around that the tpms for this car is ABS based? It's very confusing.
Abd timing belt looks very much replaced in the past year. The serpentine belt looks like it's about time to replace on the other hand. Now I'm just focusing on the codes and maintaining the car. It definitely needed intake cleaning to breathe better. Is there anything major thread on basic maintenance for this car after 200K miles? The more I find in this forum the more miscellaneous I find that can be lurking future problems.
ANYWAYS, I now look to replace the entire nav+Audio with the Teyes cc3 2K kit they sell for the car. I've been doing some research but mostly on the android head unit side. Now I reach my questions....
- What are the issues swapping out nav+audio all together?
- Since I'm swapping out the amp. I'm assuming I can run whatever rear sub I want providing the dimensions are correct without having to do a whole bunch of rewiring shenanigans like someone would with the factory amp.
- What the dimensions of the rear deck to see about possible subs to use that still give a mostly stock look.
As far as the AC Ducts that feed to the vents... I'm planning on going out to junked ls430 to research on hand if it's possible to ah "Replace" the ducts on mine to the higher version. Since it's nothing but plastic tubing from what I see online. Now to be frank. I'm going to order everything as the ML Version, just asking to either order the different face plate or order it separately in addition to the main order. I've heard very good reviews of the brand and don't expect it to be a complete regret of a decision. More updates after I leave this frozen final frontier of AK.
