Replacing headlight assembly help 1996 LS400
Old Feb 2, 2023 | 08:20 PM
winter4w's Avatar
winter4w
Default Replacing headlight assembly help 1996 LS400
Car: 1996 Lexus LS400
Okay so I am replacing my headlight assembly and I was able to pull it out however I can't seem to figure out the process on putting it back in?!? What is the trick to slind the new headlamp in place?
Ive been looking around and all videos/tutorials seem to be for a 98+ or a 1st gen
Thanks
Old Feb 2, 2023 | 08:59 PM
CELSI0R's Avatar
CELSI0R
Thanks
Slide the outside facing side of the headlight (shown attached) into the fender first, so that the threaded stud goes into the hole in the fender and the lower part of the bracket rests on the headlight bracket below it
Then, pivot the inside facing side of the headlight toward the radiator, and it should meet up with the bracket on the radiator support and with the headlight bracket.
Attached Thumbnails Replacing headlight assembly help 1996 LS400-s-l1600.jpg
Old Feb 3, 2023 | 01:25 AM
winter4w's Avatar
winter4w
Thumbs up
Thank you!!!! That seems to have done the trick
Old Feb 3, 2023 | 06:19 AM
CELSI0R's Avatar
CELSI0R
Cool, glad it worked!
I think the process is permanently engraved in my mind now
nerraw117
Oct 8, 2020 10:41 AM
dks2k
Dec 16, 2005 10:12 AM
