Rear struts Bilstein/Tanabe question...
Old Oct 27, 2022 | 09:27 PM
Zaks's Avatar
Zaks
Default Rear struts Bilstein/Tanabe question...
I have the Bilstein struts and want to raise the setting from lower perch to upper... I'm curious if this has been done or is possible... Can I fit the spring compressors (the ones you can rent from a local auto parts store) in there to compress the spring enough to move the perch setting without removing the whole unit from the car?
Old Oct 28, 2022 | 10:05 AM
Losiracer2's Avatar
Losiracer2
should be able to, you'll just have to raise it about an inch maybe inch and a half to be able to unclip the c clip move it to the higher perch. I have the same shocks all around and my rear is sagging a bit, so when I initially set them all at the lower perch I didn't realize it would look so off.
The rear springs are a very low spring rate and not under as much tension as the fronts, so compressing them should be rather easy.
ikhanbbb
Mar 19, 2014 07:12 PM
afracer
Apr 25, 2013 06:22 AM
das277
Oct 23, 2009 09:25 PM
patyz
Dec 28, 2005 02:58 AM
