P0155 Error Code on 1999 LS400
Old Mar 24, 2022 | 10:04 AM
sguagliard's Avatar
sguagliard
6th Gear
Default P0155 Error Code on 1999 LS400
Hello. Can anyone tell me which fuse would be related to the oxygen sensor and its location. Also, where is exact location of the oxygen sensor? Thanks.
Old Mar 24, 2022 | 11:32 AM
RA40's Avatar
RA40
Super Moderator
No fuse to replace. O2 sensors are service interval checks at 100K miles so depending on miles of your car, they are likely due to be replaced. This is the passenger side bank 1 sensor. Replace both of the bank 1 sensors. They are located just above the catalytic converters accessed from the bottom. They are pretty easy to access and if your car has been in FL all this time they should not pose a problem to get out as a DIY service. Spray a penetrating liquid to help in removal. This is about a 5-10 minute per side job. Unclip the wiring connector and use a 22mm or O2 socket to remove. Apply a slight dab of the copper anti-seize included with sensor on the threads, screw in and connect wiring connector, done.
Also suggested would be the engine coolant temp sensor replacement.
Old Mar 24, 2022 | 06:55 PM
Yamae's Avatar
Yamae
In case you also have codes P0135 and P10X (MAF related) together, there may be a possibility that a fuse EFI-No2 (for O2 sensors and a MAF) is open. But the code P0155 alone simply means the open heater of the O2 sensor B2S1.
jdmtruong
13
Oct 7, 2023 11:44 AM
qewani1
May 26, 2021 10:34 AM
dbullen
Aug 9, 2010 02:15 PM
squeekyM
Sep 26, 2006 07:36 AM
slash
Mar 5, 2005 05:48 AM
