What is a 'snap ring' ?
Old Nov 1, 2021 | 02:33 PM
fastegg's Avatar
fastegg
Default What is a 'snap ring' ?
There is one at the end of the steering wheel shaft right before the steering wheel mounts...(45201B).. My steering wheel has up & down play and just wondering if this 'snap ring' is a bearing of some sort ?
Old Nov 1, 2021 | 02:43 PM
CLLEXUSS's Avatar
CLLEXUSS
A snap ring is not a bearing, it's a ring that fits into a groove generally used around shafts to keep an assembly whatever that may be from sliding on the shaft, keeps it in place, a machined groove on the shaft that the ring snaps into place in, keeps it in place basically. Removal of the ring or rings with a snap ring tool and generally things slide off the shaft. I doubt it's an issue with the ring itself, unless you are missing the snap ring..and there is no snap-ring there..
Old Nov 1, 2021 | 03:37 PM
RA40's Avatar
RA40
Super Moderator
A pic of an external snap ring:
Old Nov 2, 2021 | 01:53 AM
fastegg's Avatar
fastegg
I see thank you.. i have an annoying amount of up & down play when you hold the steering wheel.. the bush in the sub assy must be worn... right at the end of the steering shaft is a snap ring but i now know thats not the problem.
Old Nov 2, 2021 | 11:23 PM
Lex212's Avatar
Lex212
Also FYI there are various types of pliers designed to be able to remove/install snap rings (aka “retaining rings”).
Notice how some expand as you squeeze, while others contract as you squeeze (and some are adjustable to be able to expand or contract as you squeeze).
Old Nov 8, 2021 | 09:05 PM
fastegg's Avatar
fastegg
Yes thanks.. i have many pairs
[/QUOTE]
alexkidd
Nov 19, 2017 09:11 PM
LexusK
Apr 9, 2017 05:40 AM
GISguy
Sep 14, 2016 02:43 PM
