UBER RARE Woodgrain Steering Wheel w/E-Shift
EDIT: My interior is tan and I am not converting to black.
Hey guys, just got my rare woodgrain/tan leather with e-shift buttons in for my 98 GS400 from Japan! Super excited to get it on, but first I need a matching airbag. Now I had done the research and know that an RX300 single stage airbag is a direct swap. HOWEVER, I failed to take into account that most of the threads on this topic references a BLACK wheel/airbag. The 01-03 RX300 only comes in tan (like really tan) and black...
So now I basically need help finding an airbag that will match my wheel. If you look at the pic, it looks like it could be grey in color. I swear I have a hard time differentiating between the tan and the grey (see my old thread :P).
I also need to take take into account that any airbag, other than the 01-03 RX300 airbag, will have different distances between the bolts that hold the primer/explosion unit/ whatever the correct term is.
HELP!!!!
HELP!!!!
Just find the leather horn that matches and swap the guts from the compatable (to car) bag. The little hocky puck metal actual exploding bag with appriate phase l or ll plugs into the horn that is matching tan color. That's what I did with my cherry wood wheel from an ES. Member "5t341th" did a pretty detailed write up.
Yea I see his thread (link below for those interested). Correct me if I am wrong, but these would be the steps I need to take:
Pull my wheel off my 98 GS400
Measure the distance between the holes of my single stage explosion unit
Go find an airbag that matches in color (any suggestions on which models would be a color match besides the RX?)
Make sure that the bolts are spaced the same distance apart as the holes on my single stage explosion unit so that it lines up correctly
Swap out the dual stage for my single stage
Reinstall!
https://www.clublexus.com/forums/gs-...e-airbags.html
Why can't an 01+ 2GS airbag work again? I can't just swap out the explosion unit from my GS400 to an 01+ bag? Or somehow find an 01+ 2GS airbag that has the single stage plug? All the "01+ GS300 Airbags" I'm seeing on ebay all seem to be single stage. They only have one connector? Am I missing something cause I was reading old threads about how only some older 01 models had single stage...
Reinstall!
Reinstall!
Reinstall!
Just get whatever airbag that fits your wheel and is the right color you want. And if your current igniter is the wrong size to bolt into the bag post a pic of the bag you are going to use and if you need a single or dual igniter and I can link you to a proper one to buy or I have a few also and may have one that works for you. It's easy stuff. You can PM me if you like as well and I can help you out..
LexusK (04-07-17)
Ive seen many 1998 through 2005 air bags for the GS and have yet to come across a dual stage airbag. I know they are out there but I have yet to see one.
I couldnt imagine trying that with just a screwdriver. You could maybe try gloves for better grip, or smacking the end of the screwdriver to shock it. I used a T30 bit with a ratchet to
break them loose with no problem
LexusK (04-09-17)
LexusK (04-09-17)
RikTT
SC400 / 300 Classifieds
14
09-14-13 07:34 PM
Pspice
03-09-10 04:12 AM
