Molding separation?
Old Oct 1, 2003 | 07:32 AM
acf's Avatar
acf
Default Molding separation?
Check out this pic. It seems like the plastic molding has detached slightly from the door frame but when I look at it its hard to tell how it was attached in the first place. I can push it into place and it "springs" back out. Not sure how to fix this. Any ideas?
Old Oct 1, 2003 | 11:06 AM
ATSOU's Avatar
ATSOU
What year is you LS? There should be some screws on each corner of the door to hold the lower panel. Also there are some double-side tapes too. You don't want to replace that lower panel.....that panel along cost around $500.
Old Oct 1, 2003 | 11:19 AM
acf's Avatar
acf
Thanks, its a '97.
Old Oct 1, 2003 | 09:22 PM
LexLS's Avatar
LexLS
Post
I think you would have to take apart the door to figure out what's wrong. It doesn't look too bad to me. I wouldn't worry about that man. Keep your car clean and it shouldn't be too noticeable.
Old Oct 2, 2003 | 06:41 AM
acf's Avatar
acf
Maybe some kinda glue or tape is the solution because it just seems like I need in to hold in place when pushed in a little bit more.
Old Oct 2, 2003 | 08:11 AM
LexLS's Avatar
LexLS
Post
Try some Super Glue or Epoxy. Then put a clamp on the panel and let it dry for a while.
cdew002
GX - 1st Gen (2003-2009)
Jun 25, 2016 07:26 PM
siccas
Aug 14, 2013 10:28 PM
tahiles
Nov 13, 2012 05:21 AM
1sxyrxy
Feb 9, 2006 05:34 PM
Dat
Nov 26, 2003 05:52 PM
