Suspension spring discussions (The Mother Thread)
Old Feb 25, 2010 | 08:15 AM
  #301
justinp95's Avatar
justinp95
Originally Posted by steveski
I had (4) finger gaps in the beginning and gradually lowered it to where it is today. Now there is less than (1). Here it is today with H&R and Bilstein HD struts set to lowest spring perch and 4" progressive poly foam bump stops installed in all. It is complete until I replace it soon.
What did you have to do to your fenders to get those wheels to fit? It seems some wheels i found are .5" larger than yours and i was wondering what i would have to do to get them to fit.
(2) 18X9 Drifz Venom Gunmetal +35
(2) 18X10 Drifz Venom Gunmetal +35
(2) 245/40ZR 18 Nexen 3000 (fronts)
(2) 275/35ZR18 Nexen 3000 (rears)
Old Apr 24, 2010 | 04:28 PM
  #302
BluLS's Avatar
BluLS
Default PIC REQUEST:LS400 on lowering springs
i am looking to buy lowering springs for my car but i want to see how low it will be before i buy them. the springs i found are tanabe 1.8"front 1.5"rear
i have stock wheels but i am planning on putting 19's
please post pics if you have any
-thanks
Old Apr 24, 2010 | 07:15 PM
  #303
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
you need to search.
Old Apr 24, 2010 | 08:00 PM
  #304
trukn1's Avatar
trukn1
NELOC Mod
Been discussed MANY times before,,,
https://www.clublexus.com/forums/ls4...eel-setup.html
https://www.clublexus.com/forums/ls4...of-ur-car.html
https://www.clublexus.com/forums/ls4...-in-yours.html
https://www.clublexus.com/forums/ls4...g-springs.html
Just to name a few. This should keep ou busy for awhile.
Old Apr 24, 2010 | 09:59 PM
  #305
yellowsub's Avatar
yellowsub
i'll have my 19in MAE's on in about a month but u still can kinda get an idea of what the drop would be like
Old Apr 25, 2010 | 12:41 AM
  #306
whit3b0y's Avatar
whit3b0y
i have the tanabe springs and 19's, i like the way it sits....but... kinda thinking stance is a bit off... 2. and 1.8 i think would be better. Prolly ganna swap out for coilovers.
Old Apr 26, 2010 | 08:17 AM
  #307
justinp95's Avatar
justinp95
Got any better pics? What are your wheel specs?
Old Apr 27, 2010 | 04:55 PM
  #308
BluLS's Avatar
BluLS
thanks for the help everybody...i would also like to see more pics of this car
Old Jun 13, 2010 | 08:47 AM
  #309
4DGS's Avatar
4DGS
Default Best drop on springs
Yes I've searched for this.
What is the best drop on springs?(lowest) I've seen the tanabes and they seem to be the lowest (1.8 and 1.5?) the eibach don't have a sport line and the pro kit aren't low enough. Anyone else dropped on just springs?
Also, how strong are the stock struts? Will they be able to handle a 2" drop or are they going to be pooched pretty quick?
Thanks.
Edit; it's a 91 LS400
Old Jun 13, 2010 | 10:38 AM
  #310
genetic's Avatar
genetic
tanabes + bilstein hd
verdict: get coilovers
Old Jun 13, 2010 | 10:47 AM
  #311
PureDrifter
BahHumBug
CL Folding 100,000
last i checked they dont make the bilsteins for the 1LS. besides that, tanabe+Bilstein is a poor choice imo because the dampers are working wayy out of spec. I actually contacted Bilstein about them and when i gave them the DF210 specs (length+spring rate) they told me as such
Old Jun 13, 2010 | 11:28 AM
  #312
trukn1's Avatar
trukn1
NELOC Mod
1. coilovers are goingto be your best option to get the LOWEST drop on the 1LS plus you will have the added benefit of versitile adjustability(depending on which coilover set you get).
2. Stock struts will blow VERY easily with low drops. You are already geting the springs and you will have to disassemble the strut assembly, just replace the struts while you have them apart.
3. Genetic,,,, Bilstein makes NOTHING for the 1LS so thisis not even an option.
Old Jun 13, 2010 | 11:43 AM
  #313
4DGS's Avatar
4DGS
Not sure if you guys saw my intro thread, but this is my daily run around/winter vehicle. I was trying to avoid buying coils, but I'm not full against it!
Anyone down 2"?
What kind of camber do these cars pull with just the drop? Inch to degree ratio, if anyone knows.
I have a weird feeling my stock struts are close to the end anyways, I bought the car yesterday and I'm gonna get the majority of work done on it before it's licensed and driving.
Suggestions on Coils?
Old Jun 13, 2010 | 07:50 PM
  #314
trukn1's Avatar
trukn1
NELOC Mod
Since this is going to be your daily,,,
Struts/springs,,,$600-$700
Megan coilovers,,,,- $800- $900 (cheapest, good coils for LS)
Neither of these prices include install.
LI_celsior has megans on his car and I am sure that he will chime in.
Old Jun 13, 2010 | 10:28 PM
  #315
jasonm's Avatar
jasonm
go for the megans
