Noise while turning left
Old Apr 9, 2019 | 10:36 AM
Sherl's Avatar
Sherl
Exclamation Noise while turning left
I have replaced my brakes 1000 miles ago. When i turn left my front passenger side starts creating a noise from the wheels. Not sure which part though.
Any tips for diagnostics?
Old Apr 9, 2019 | 12:44 PM
Losiracer2's Avatar
Losiracer2
Try checking the pad wear indicator and clip for it. The pass. side is the side that has both for front and rear. Maybe a clip came dislodged or something?
Also, it could be possible that the brake dust shield is rubbing the inner surface of the rotor when turning, so check clearances there.
Old Apr 9, 2019 | 01:37 PM
billydpowe's Avatar
billydpowe
Originally Posted by sherl
i have replaced my brakes 1000 miles ago. When i turn left my front passenger side starts creating a noise from the wheels. Not sure which part though.
you just got some good advice,
Old Apr 9, 2019 | 02:09 PM
Fit1too's Avatar
Fit1too
I noticed a noise on my passenger side not long after I purchased it. I raised the vehicle and rotated the tire to listen for the noise. Nest, I took the tire off and found that the wire for the brake wear sensor was rubbing the rotor. Took the slack out, repaired the damaged wire, and all is well now.
lexus-is2
Sep 8, 2011 11:32 AM
96Es
Aug 15, 2008 07:24 PM
shadow
Suspension and Brakes
May 29, 2007 08:23 AM
