ECM. Can it be repaired?
Old Nov 30, 2018 | 12:29 PM
kcfromva's Avatar
kcfromva
Default ECM. Can it be repaired?
1994 LS400 started running like crap every now and then. Chugging and hesitating. Did the normal stuff. Plugs wires cap rotor. Still had problem. Wife drove it and it left her stranded so I figure its time to pull ecm and looked inside. Burnt in between 2 capacitors right lower of picture. Can it be repaired or better off finding another one?
Old Nov 30, 2018 | 12:44 PM
bradland's Avatar
bradland
https://www.clublexus.com/forums/ls-...capacitor.html
Old Nov 30, 2018 | 01:06 PM
kcfromva's Avatar
kcfromva
I have replaced the capacitors once a couple years ago. I know about that. I am worried about the board being burnt up. Can it be repaired? I dont know so I thought I would ask here before trying to send it in to get repaired.
Old Nov 30, 2018 | 01:45 PM
bradland's Avatar
bradland
There is a vendor specializing in ECU repair within that thread. I'm sure they could answer your question in great detail...
Old Nov 30, 2018 | 01:51 PM
kcfromva's Avatar
kcfromva
ok Thanks. I will read through it again.
Old Nov 30, 2018 | 08:36 PM
Yamae's Avatar
Yamae
A burnt up board can not be easily repaired especially when the internal layer is damaged by the invaded liquid. As I see your board, the surface coating is damaged and the copper trace is darken but I can't judge the liquid damaged the internal layer or not only by a single photo. If I were you, I'd remove capacitors first and clean the board and then check how much the internal layer is damaged using a strong light and a circuit tester. The liquid is very strong alkali and the cleaning only is often not enough. You need to do the neutralization as is explained in the capacitors thread.
TruongJL
16
Jan 24, 2014 02:52 PM
LANcr3w
66
Oct 28, 2013 11:01 PM
LANcr3w
Apr 9, 2013 10:36 AM
UNDR8D
21
Sep 26, 2012 04:57 PM
maxgee
Jul 12, 2010 05:10 PM
