Headlight leveling on dashboard
ToneOmni- Being new here (like me) you might not know Yamae yet. He is the final word on all things electric for repairs. So you get free advice that you often times couldnt even pay for elsewhere.
Just do exactly as he says and you will be golden.Even if it seems counter-intuitive to what you are seeing
,he is right.
,he is right.
Scraape=this is exactly what was happening in my 1999 . Headlight Levelling Notification popped up, Battery Charge Light Came on, and eventually both just went away.
I attributed the funky stuff going on to possibly power steering fluid(ATF) leaking on the alternator. But it could also be an intermittent alternator on its way out or improperly installed ?
I switched out my alternator for an 01 LS430 unit for peace of mind. Never swapped the battery
Your alternator is dying and will quit the generation completely soon. A small P/S fluid leak tends to cause your type of problem due to the reason that the leaked P/S fluid goes to brushes and the commutator in the alternator and the current path is disabled as you drive. You need to fix those 2 before you might be forced to stop at somewhere.
I am getting the same indicator along with the battery warning light. I have changed the battery and alternator, it ran for 4 days with no indicators and then these 2 came on at the same time. We didn't fix the headlight sensor, so I am hoping that the battery light is a fluke since that has all been fixed or replaced. The mechanic said that the I am getting a great charge. Has anyone else experienced this?
im getting those same errors from my 99’ do you know how to fix it?
rome99LS
25
Aug 9, 2017 11:05 AM
TONY1022
Mar 20, 2014 09:15 PM
