Ls400 memory seat . Side mirror problem.
Old Mar 10, 2018 | 12:00 AM
Daesunglee's Avatar
Daesunglee
Default Ls400 memory seat . Side mirror problem.
Hello, I would like to contact you again.
Please understand that it was written in translation.
my car ls400 2000year.
Driver's window can be opened and closed
Drivers can not open or close other seat windows.
On the passenger seat, if the door is unlocked, the window is opened.
Unable to open window if locked
The rear seat can not be opened if it is also locked.
Window can be opened when in an unlocked state.
Side mirror (s) not adjustable
Memory seat inoperative.
Lock unlock inoperative
Disable the Easy Access Protocol
Ask earnestly for help on what to check.
Have a great day today
Old Mar 10, 2018 | 06:20 AM
bornking's Avatar
bornking
Sounds like an electrical problem.
Start with checking for shorts and the fuses.
Then move onto individual switches, make sure they work.
Then check the ECU
Old Mar 10, 2018 | 07:25 AM
Daesunglee's Avatar
Daesunglee
Default Ah
Then check the ECU
Thank you for your answer.
I would like to ask what ecu is used in relation to the ecu.
Old Mar 10, 2018 | 07:47 PM
bornking's Avatar
bornking
ECU/ECM = Engine control module
It's the main computer in the car if I'm not mistaken. When you start getting multiple issues like that, and can rule out switches and relays and fuses, then I'd check the ECU....
I assume you will check the wiring for shorts...
Daesunglee
IS - 1st Gen (2001-2005)
Mar 9, 2018 11:48 PM
jimisbell
Feb 6, 2018 09:35 PM
bjhille
Jul 12, 2013 04:23 PM
BigGreen
Nov 4, 2009 12:48 PM
nistno
May 9, 2009 10:37 AM
