Replace Climate Control With Something Else?
Old Jan 30, 2018 | 08:26 PM
Moarpower's Avatar
Moarpower
Default Replace Climate Control With Something Else?
Hi guys.
I am thinking about removing the giant climate control and air filtration system in my 1990 Celsior. This thing is monstrous, and I would like to make more room in my car for FI. ANyo thirdparty AC products recommended? So far Im likely going with a modded Vintage Air kit
Old Jan 30, 2018 | 08:31 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
Are you talking about removing the heater core/blower assy.? It's larger than aftermarket units because it was engineered to be much more durable and work under much harsher conditions than any aftermarket units. I don't know why you need under-dash space for FI or if you're referring to the AC condensor/drier how much space you expect to free up, but no, aftermarket (vintage air/similar) isn't going to perform to a near-stock level in the long term.
Old Jan 30, 2018 | 09:52 PM
Moarpower's Avatar
Moarpower
Mine currently doesnt perform at all. The build will consist of FI with intercooler and airbags in the trunk, so I will be removing the massive air filtration system. Along with everything under the hood. I may end up not using any form of aircon at all as this will not be a daily driven vehicle once I am finally done. . I dont need it to perform like the 28 year old unit. I have a vintage air system in an old wagon that is more than adequate for my needs and takes up a fraction of the space of the system in my celsior. Its all about cutting weight and gaining space. The unit in the trunk is the main space I want to free up.
I understand the reason for the oem system being so large. But it is now nearly 30 years and it is not something I want to rely on. This is the same reason Im replacing the ECU. Old tech is old tech, and things tend to go south quite quickly after 20 years
debzfree
RX - 3rd Gen (2010-2015)
Mar 2, 2022 01:10 PM
twinturbov
LX - 3rd Gen (2008-2021)
Jan 13, 2018 09:05 AM
MrSoarer
Mar 1, 2008 04:20 PM
ninja2000
GX - 1st Gen (2003-2009)
Oct 19, 2005 10:27 PM
agc
May 2, 2005 06:36 PM
