Climate Control System Error
Old Aug 17, 2018 | 11:54 AM
debzfree's Avatar
debzfree
Unhappy Climate Control System Error
It seems like every time it rains and I try to use my front defroster I receive a Climate Control System Error. I try to shut off the air and turn it back on but the error stays unless I shut off my vehicle. The A/C won't work either. It's very annoying and a bit dangerous as we are getting some pretty heavy rains here in FL.
Any idea what could be causing this and what I should do? I have replaced the cabin air filter twice myself. I am not sure if that affects the issue or not.
Old Aug 17, 2018 | 02:03 PM
vlad_a's Avatar
vlad_a
Front defroster turns on the AC. Silly question in FL, but is your AC functional otherwise?
I would venture a guess that the HVAC control that changes air routing has an issue.
Can you set HVAC to Feet and Windshield setting? Or does it generate the same error?
Also, what is the year and mileage on the vehicle?
Old Aug 18, 2018 | 07:24 AM
N4TECguy's Avatar
N4TECguy
Does the error pop up immediately when you switch to defrost or does it take a few mins? Is it possible that the AC evaporator is icing over? I would try running recirc when it rains, it may help a little to pull in drier air to prevent icing on the evaporator. Not sure if the RX allows defrost with recirc though, some vehicles don't.
Old Aug 19, 2018 | 01:23 PM
debzfree's Avatar
debzfree
I have a 2011 RX350. My mileage is around 88K. The a/c works fine any other time. I'll try the recirculated air next time and see if that helps.
Old Mar 2, 2022 | 01:10 PM
HokieGear's Avatar
HokieGear
Justhad this climate error and changing the air filter fixed it.
colfax
Nov 11, 2018 01:42 PM
twinturbov
LX - 3rd Gen (2008-2021)
Jan 13, 2018 09:05 AM
elemgee
Jan 7, 2010 08:21 AM
agc
May 2, 2005 06:36 PM
sc300jon
May 17, 2001 08:11 AM
