Coolant leak
Old Jan 1, 2018 | 12:03 PM
rlhewlett's Avatar
rlhewlett
Default Coolant leak
My 1995 Lexus LS400 started leaking coolant from underneath. Looks like it’s leaking from somewhere on my transmission or around it. Any idea of what may be going on or will this be and expensive fix
Old Jan 1, 2018 | 02:00 PM
bradland's Avatar
bradland
A small coolant leak will often evaporate as it drips over hot engine parts. The closest coolant path to the trans is the heater valve / heater core are at the firewall. Look at the hoses between the engine and firewall and you'll probably find the source of the problem.
Old Jan 1, 2018 | 04:55 PM
Banshee365's Avatar
Banshee365
The rear coolant bridge would drip on the trans as well.
Old Jan 1, 2018 | 11:27 PM
rlhewlett's Avatar
rlhewlett
Thumbs up Coolant leak
Thanks bradland
inwill look into that ASAP. That actually makes since from where the leak is
Old Jan 2, 2018 | 08:32 AM
YODAONE's Avatar
YODAONE
Check water control valve..located on engine side firewall center.
Wrap paper towel around valve to determine if leaking (coolant will leave red stain)
Superfast1
Jun 30, 2018 10:06 PM
pman6
Maintenance
Nov 17, 2014 05:48 AM
bryanc182
Oct 14, 2011 02:38 PM
trez_doz
Oct 19, 2010 05:02 PM
