Headight ballast
Old Aug 30, 2016 | 12:29 PM
shmuliebz's Avatar
shmuliebz
Originally Posted by apolloauto
This is the correct link for the ballast http://apolloautolights.com/index.ph...roduct_id=1558 and the price is $52.00
That's not the correct unit for my lexus
Old Aug 30, 2016 | 01:23 PM
apolloauto's Avatar
apolloauto
Former Sponsor
Whats the Year ,Make and model of your lexus and if you can please send my a picture of your original ballast thank you.
Old Aug 30, 2016 | 09:04 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
Originally Posted by timmy0tool
could it be that the failed ballast was due to those butt connectors used on the power lines? not likely as I would think the butt connectors themselves would fail first and not the wires that powered the bulbs. never seen a failure like the one you pictured.
Unlikely. The failure on these denso ballasts is usually due to water infiltration because the ballasts are not very waterproof since they are usually mounted in locations far from water (ie- under or inside the headlights housings). You can see the corrosion on the circuit board he posted.
Old Aug 30, 2016 | 09:05 PM
PureDrifter
BahHumBug
CL Folding 100,000
In the first post of this thread he posted the year and model of his car, and in laters posts we determined that the ballast in the car currently is the incorrect ballst from a later car. The one I linked from ebay (and the one you linked initially) were the correct ballasts for his car.
Old Aug 31, 2016 | 08:27 PM
shmuliebz's Avatar
shmuliebz
I ordered a used one from ebay like you suggested
do you think I can seal it with some silicone sealant or does it need to be open or it will overheat?
Old Sep 1, 2016 | 05:33 AM
PureDrifter
BahHumBug
CL Folding 100,000
Don't crack open a good ballast. Silicone is not needed and will not help as the cable grommets are not waterproof and the electronics will overheat if the case is fully sealed.
waterproofing ballasts is a much more complicated procedure involving thermally conductive epoxy and working with high voltage electronics with capacitors. Best left alone or to those with experience.
Good luck!
wtfsajayte
Feb 21, 2014 07:09 AM
milellie11
Jun 28, 2011 03:21 PM
rselby
Jan 31, 2010 08:37 PM
Smoothie22
17
Dec 18, 2007 08:49 PM
FinnLS
May 29, 2007 03:42 PM
