Smoke from steering column. Source?
Old Feb 25, 2016 | 10:18 AM
Rdrcr's Avatar
Rdrcr
Default Smoke from steering column. Source?
A friend just purchased a super-clean '92 LS w/160K miles. Very nice car!
While adjusting the steering wheel position a little smoke started to come out from the column. Would smoke be coming from the electric motors, or the nylon gears?
Mike
Old Feb 25, 2016 | 08:16 PM
python's Avatar
python
its ur auto steering wheel adjuster motor
Old Feb 26, 2016 | 05:18 AM
Stereorob's Avatar
Stereorob
GACK! uh, that sounds scary. is it moving up down and in out okay still?
Old Feb 26, 2016 | 08:32 AM
Rdrcr's Avatar
Rdrcr
Cool. I'll let him know.
I was in the process of warning him about not using the 'auto' feature and suggested to 'set-it-and-forget-it' when it started smoking. LOL.
Mike
Old Feb 26, 2016 | 08:39 AM
Stereorob's Avatar
Stereorob
easy fix on a stripped gear but smoke means heat, and the potential for fire, which never ends well in a car. must be a short someplace.
Old Feb 26, 2016 | 08:47 AM
Rdrcr's Avatar
Rdrcr
Mine just needed some 'grease' for the gears to get it working right.
I'll let him know he should take it in to the Dealer/Shop to diagnose the issue.
Mike
Old Feb 26, 2016 | 12:10 PM
timmy0tool's Avatar
timmy0tool
don't take it to the dealer just yet! there is a fix on the FAQ section. point him towards that first before going to a shop.
Old Feb 26, 2016 | 02:04 PM
Rdrcr's Avatar
Rdrcr
I haven't read the entire thread. Do they discuss a fix for this specific issue? His works...but, it has some obvious electrical issue with the motor and smokes.
Mike
Old Feb 27, 2016 | 06:11 PM
dicer's Avatar
dicer
At a minimum at the dealer that is probably a $600. fix. Unless they up sell it. I'd get some covers out of the way and try to track down the smoke. A $10. wreaking yard part may fix it.
Old Feb 28, 2016 | 09:28 AM
LSpho's Avatar
LSpho
didn't someone have a manual tilt fix somewhere? or am I mistaken that for the set it and disconnect the auto tilt. Man fking lexus, my door panel was chopped off so I can open the door manually via pulling the latch...
I'm only at 11xxxx
I need a whole new lock unit for the driver door, I'm tempted to convert all my door to pullstraps like some porches or race cars...
Old Feb 29, 2016 | 09:08 AM
Rdrcr's Avatar
Rdrcr
Most of the column fixes deal with the gear. I had the same issue with my '94. No problem there. However, a smoking motor? Possible short? Not sure if there is an easy fix for that one...
And, you're right the Dealer won't be cheap.
Mike
wthrman2
RC - 1st Gen (2015-present)
Jun 17, 2019 08:02 PM
ryanSC300lover
Dec 19, 2017 11:13 AM
jay-b
Apr 10, 2015 07:12 AM
jwloysr
Oct 4, 2011 07:23 AM
PhilipMSPT
Jul 17, 2007 01:08 PM
