Engine code: p1755/1765
Old May 28, 2015 | 06:18 PM
gr8wyt's Avatar
gr8wyt
Default Engine code: p1755/1765
i got these codes and cant really find a definitive answer. anyone get these codes before?
Old May 28, 2015 | 06:34 PM
timmy0tool's Avatar
timmy0tool
P1755 = Intermediate Speed Sensor (ISS) Malfunction
P1765 = Linear Shift Solenoid Circuit Fault
what year car? and what mileage are you on?
Old May 28, 2015 | 10:22 PM
Yamae's Avatar
Yamae
Are you sure on this?
I'd rather check the "Lock Up Linear Solenoid" when at P1755 or the ECU.
Old Jun 1, 2015 | 11:15 AM
gr8wyt's Avatar
gr8wyt
Its 97 ls400. And about 180k. I followed your ecu rebuild guide because i had 32 codes. Not sure if these two codes were there before i did the ecu but are they only codes that are coming up after the i did the ecu
Old Jun 1, 2015 | 07:58 PM
Yamae's Avatar
Yamae
P1755 is referring to the "Lock up Linear Solenoid".
P1765 is referring to the "Clutch Control Solenoid".
I wonder why Timmy wrote about an ISS.
Anyway those codes indicate that solenoids above are open or short circuited. Sometimes connection issues or an failed ECU also generates random codes. So you need to distinguish which is causing the problem.
Do you have any AT problem now?
If not, simply erase those codes using a scanner. Judging from your situation reporting P codes, you are in use of a scanner. Codes stored in the non volatile memory can't be erased by a battery disconnection.
If the codes are coming back, you need to check solenoids, connections or the ECU. Did you replace all ECU capacitors properly?
Inform me the result and I'll give you a next step to do.
Old Jun 1, 2015 | 09:33 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
sounds like dead trans solenoid or solenoid wiring harness.
Old Oct 15, 2016 | 03:52 AM
LEXUSA400's Avatar
LEXUSA400
I'm getting these codes and P0770 Shift Solenoid E. 1997 with 138,000 miles.
When I clear these codes with a scanner they come right back, even before starting the engine or shifting out of park which suggests the solenoid is stuck ON. Transmission shifts more firmly than it should, into reverse as well as thru the gears and down shifting, especially when slowing to a stop, 2nd to 1st..
I recently replaced all 6 of the capacitors in my ECU. I also replaced the Traction Control module due to another issue which is now cleared.
Can I check to see if this is a wiring issue or something other than the actual solenoid?
Are there any other ECU upgrades/repairs/mods I need to do for this issue or in general?
Old Oct 15, 2016 | 01:31 PM
PureDrifter
BahHumBug
CL Folding 100,000
Sounds like you've answered your own questions. If you have access to a toyota dealership scanner you can have them run some advanced diagnostics that are otherwise inaccessible through normal OBDII scanners. It could be either a dead solenoid or an issue with the harness. on that generation transmission I would lean towards solenoid.
Old Oct 15, 2016 | 01:47 PM
LEXUSA400's Avatar
LEXUSA400
Thanks for the info.
Are there any good aftermarket solenoids or should I just go with genuine Toyota?
I think the best price I've found is $225. Any suggestions?
Old Oct 15, 2016 | 06:17 PM
PureDrifter
BahHumBug
CL Folding 100,000
For trans internals I prefer OEM
Old Oct 16, 2016 | 02:23 AM
LEXUSA400's Avatar
LEXUSA400
Where do you like to shop for OEM parts?
simplecar
RX - 1st Gen (1999-2003)
May 30, 2019 05:29 PM
Nosebleed
May 31, 2013 04:36 PM
ScDre
Jul 9, 2012 02:47 PM
jhuang2668
Jun 24, 2010 08:54 AM
