LS400 90 water temp sensor problem
Old Jan 20, 2014 | 11:37 PM
ExiledWolf84's Avatar
ExiledWolf84
I was in a bind when i did mine and i put a "BWD" branded one in, which was about $30 or so at the local parts store. It looked the same as the Factory unit, and has performed quite well so far.. I still plan on changing it back to OEM during the soon to be done tuneup though, as it felt significantly lighter compared to the original one
Old Jan 21, 2014 | 05:44 AM
LScowboyLS's Avatar
LScowboyLS
many people seem to like these aftermarket engine coolant temperature sensors, but I am staying with OEM Toyota since you can get them on ebay for $41 shipped and they last for over 10 years, because this is one of the most important sensors on the entire car, and just not a place where I am worried about saving 10 or 20 bucks!
Old Jan 22, 2014 | 06:56 PM
qha_vn's Avatar
qha_vn
need advise:
the seller sends me these images and ask me to confirm before he ship. I am not sure how to respond.
should i ask the money back or else? btw, the seller is rated high and very responsive.
Old Jan 26, 2014 | 08:50 PM
qha_vn's Avatar
qha_vn
I've offered seller money back if he cant ensure it will fit. now hunting for OEM. the one recommended by LScowboyLS is not contactable unfortunately.
Old Jan 26, 2014 | 09:04 PM
LScowboyLS's Avatar
LScowboyLS
I am just not sure who ships to Vietnam and also not sure if your want genuine Toyota
I have not seen these for sale in the brand of Toyota's OEM supplier in several months
the one you pictured would probably fit, but that is a pretty sleazy brand - let me post you some links to the genuine Toyota part, give me a few minutes
Old Jan 26, 2014 | 09:22 PM
LScowboyLS's Avatar
LScowboyLS
OK this one is genuine Toyota OEM and also ships to Vietnam!
www.ebay.com/itm/251432985488
that is a pretty good deal, because if you just walk into a Lexus or Toyota dealership parts department in USA, you will pay about $69 + tax for this same Toyota part! - so it's like free shipping!
Old Jan 26, 2014 | 10:11 PM
qha_vn's Avatar
qha_vn
Thank you very much LScowboyLS, i am ordering.
I will need to strengthen my ebay searching skills
Old Jan 26, 2014 | 11:52 PM
LScowboyLS's Avatar
LScowboyLS
on some sensors, like the sensor in bottom of the radiator for the electric fan, aftermarket is OK, but this sensor is one of the most critical on the entire car! - so OEM Toyota is the right choice!
Old Jan 27, 2014 | 01:56 AM
qha_vn's Avatar
qha_vn
please tell me where the ECT sensor is in this picture. I got confused after reading this post
I already tell seller hold refund unitl i can be sure my mechanic took the right sensor out. the image is an item listed on ebay claimed to be from 90-94 ls400
Old Jan 27, 2014 | 08:26 AM
ExiledWolf84
It's the greenish looking plug facing upwards on the far left, in between the two holes where the bolts go to anchor that whole assembly in.
Old Jan 27, 2014 | 05:37 PM
qha_vn's Avatar
qha_vn
so it was exactly the one my mechanic took out and the after market replacement wont fit.
Old Jan 28, 2014 | 10:19 AM
BeLSNow111's Avatar
BeLSNow111
Are the 'water temp sensor' and ECTS the same sensor?
Old Jan 28, 2014 | 12:38 PM
LScowboyLS's Avatar
LScowboyLS
Yes, the Engine Coolant Temperature Sensor (ECTS) part number 89422-20010 is the green one below and the one that feeds the ECU so that it can make correct decisions on how to run the car correctly for the conditions - beside it, you have the gauge sensor (gray sensor below) which only is for the gauge in the cluster, and then there is a sensor in the bottom corner of the radiator for the electric fan.
Attachment 498617
Old Jan 28, 2014 | 12:53 PM
LScowboyLS's Avatar
LScowboyLS
just to further clarify what YoshiMan said earlier, in your pic, the ECT sensor is the farthest one on the left, and the sender for the dash gauge is the one right beside it an inch away
Old Jan 28, 2014 | 01:36 PM
BeLSNow111's Avatar
BeLSNow111
Thank you for confirming cowboy
LS40099
Jun 9, 2019 04:37 PM
jaaa
Aug 31, 2017 04:38 PM
MikeBacon
16
Oct 16, 2013 12:37 AM
