Check engine light and Trac light flashing
Old Dec 23, 2013 | 05:50 PM
BTINSLEY's Avatar
BTINSLEY
Default Check engine light and Trac light flashing
I had a new starter put on my 1995 Lexus LS 400 , Saturday and now the check engine light and Trac light is flashing and engine is running rough , it ran smooth as silk before the work was done . Has anyone come across this problem , and what was the solution to fix it ?
Old Dec 23, 2013 | 05:53 PM
SynicalVip's Avatar
SynicalVip
Both of them are flashing?
Old Dec 23, 2013 | 05:57 PM
BTINSLEY's Avatar
BTINSLEY
Yes they are both flashing
Old Dec 23, 2013 | 06:54 PM
SynicalVip's Avatar
SynicalVip
I think when check engine light flashes it usually mean misfiring. Are you able to get the car scan for codes?
Old Dec 23, 2013 | 07:07 PM
LScowboyLS's Avatar
LScowboyLS
to scan the car if you don't have a scanner, either go to an auto parts chain store such as Advance Auto Parts, O'Reilly, or Autozone and they will scan the car for free and give you a print-out, or else you can order a very capable scanner for only $17 to your door here
then come back here and tell us the codes you got
Old Dec 24, 2013 | 06:20 PM
BTINSLEY's Avatar
BTINSLEY
I had mechanic recheck his work , he found three spark plug wires pinched , he replace them , now it runs fantastic .
kkochan
Dec 10, 2023 05:27 PM
chriswins
Aug 20, 2009 05:27 PM
JMIG118
Jun 1, 2008 11:48 AM
foostu
RX - 1st Gen (1999-2003)
Jul 8, 2007 10:04 PM
smuv gs3
GS - 1st Gen (1993-1997)
Dec 17, 2005 08:15 AM
