Crankshaft Pulley question 2000 LS400
Old Oct 16, 2013 | 06:36 AM
MrStiles's Avatar
MrStiles
Default Engine vibration question 2000 LS400 (edit with fix)
Hey guys,
I am trying to diagnose a problem with my LS400. The car has a vibration coming from the engine bay only when the rpms are around 1400-1700. So if I am accelerating through any gear it always vibrates at that point. If I am driving about 50mph keeping the rpm at 1500 it is vibrating, if I put the engine into neutral and coast at 50mph, the vibration immediately stops. So my guess is first the crankshaft pulley. I understand this to be the harmonic balancer? Any input would be greatly appreciated here. I am going to take the car into my local shop and have them replace whatever it is that I think would be the issue.
*Edit - See comments below and my post with pictures for the answer to my worries!
Last edited by MrStiles; Oct 17, 2013 at 06:05 AM. Reason: Asked about a vibration and figured out the problem
Old Oct 16, 2013 | 06:48 AM
2GSKaizen's Avatar
2GSKaizen
Could possibly be a motor mount / transmission mount. I say this because you get it when the car is in gear, and it stops when you put it in Neutral. In my experiences a harmonic balancer is going to cause roughly the same level of vibration whether the car is in gear or not.
Old Oct 16, 2013 | 06:59 AM
Yamae's Avatar
Yamae
+1 for the transmission mount.
Old Oct 16, 2013 | 08:09 AM
LScowboyLS's Avatar
LScowboyLS
+2 for transmission mount
make SURE to get the genuine Toyota part, it is very cheap to buy and very easy to install yourself!
if that doesn't cure all of the vibration, then get the two main motor mounts, and they too must be genuine Toyota (aftermarket are complete garbage) - the two main motor mounts are not so low cost and much more of a pain to install yourself than transmission mount.
I highly doubt there is anything wrong with your harmonic balancer (crankshaft pulley)
Old Oct 16, 2013 | 08:52 AM
MrStiles's Avatar
MrStiles
Wow thanks for the help guys. Glad to see this is a unanimous suggestion Calling my nearest dealership today for that transmission mount! Any good diy threads for this job?
Old Oct 16, 2013 | 09:41 AM
LScowboyLS's Avatar
LScowboyLS
the part number is 12371-50060 - don't over-pay - make them give you a nice discount, as an example, Lexus of South Atlanta charges $36
just search on here for tutorials on this job, there are several!
Old Oct 16, 2013 | 10:06 AM
timmy0tool's Avatar
timmy0tool
late to the party but yes, transmission mount!
Old Oct 17, 2013 | 06:11 AM
MrStiles's Avatar
MrStiles
You guys were spot on! Here's a couple pictures to show that the mount was actually broken. Once I put the new one in, the vibration was gone and everything was right with the world once more lol
Attached Thumbnails Crankshaft Pulley question 2000 LS400-1016131932.jpg   Crankshaft Pulley question 2000 LS400-1016131941a.jpg
Old Oct 17, 2013 | 09:03 AM
Yamae's Avatar
Yamae
Congratulations on your quick fix.
I have a question, MrStiles. Didn't you feel that 1 or 2cylinders were misfiring at around 1500rpm when the problem was going on?
When my car had your type of vibration, it was a month after I've changed spark plugs. I initially thought there were mis-firings. But it turned out to be the transmission mount.
Old Oct 19, 2013 | 08:43 AM
2GSKaizen's Avatar
2GSKaizen
Excellent! Glad we were able to help!
Old Oct 19, 2013 | 10:35 AM
LScowboyLS's Avatar
LScowboyLS
I am most impressed at how you were able to get you car upside-down in order to take that photo!
Old Oct 24, 2013 | 07:37 AM
Privateer's Avatar
Privateer
HAHAHA, I was thinking the very same thing when i saw that picture, Cowboy!
Old Oct 24, 2013 | 12:55 PM
timmy0tool's Avatar
timmy0tool
LOL! how many miles does the car have? i'd like to note the typical mileage the owners start to notice, though of course it all depends on the owner too, plus climate, and driving habits, etc.
Old Oct 24, 2013 | 01:46 PM
LScowboyLS's Avatar
LScowboyLS
I have definitely seen these break in less than 100K
Old Oct 24, 2013 | 04:12 PM
Yamae's Avatar
Yamae
I found that mine was in this condition at 88K miles / 141K km when the vibration was quite noticeable. Judging from the level of the crack and minor vibrations started months ago, the breakage must have started at 80K or earlier.
