That is a very wide tire for a 1-LS. Conservative spec would be a 9.5" wide rim but it can be stretched to 10.5 or so. Initially I would say do not buy. In addition, this will be a pretty heavy combo to deal with. Roughly, this is a 28.7" diameter.
I know its wide. Needs new tires anyway. Thought bout rolling and pulling the front and rear so it'll fit better. And the replace the tires with 255/35/20. I'm going for the hellaflush fitment.
Reason: Profanity adjustment.
Also, they were on a 00 gs300.. idk if that means anything
if they came off a gs300 they should fit, however the question is, was that car lowered? as soon as you lower your car on these wheels, you'll run into clearance problems.
if you're doing this for the hella flush fitment, these wheels may not get you there. they will get you dub fitment for sure.
I'm not lowering it right now any way. I do want to lower it, but idk if I'm gona slam it or not. At stock highth, I bottem out on speed bumps out here. Crap is crazy high! Steep drive ways also! I do prefer to ride low. That's why I'm also looking at some XXR 522 +20 offset 18x8.5 wheels.
