ls 400 water pump
Old 09-13-02, 09:05 PM
okfine
okfine's Avatar
Unhappy ls 400 water pump
i have a small leak in my water pump on a 93 ls400 223,000 miles how long can i go before i have to replace it and how much will it cost me?
Old 09-13-02, 09:32 PM
wwest
wwest's Avatar
Default assuming
The leak is around the input shaft then the seal has failed and you now have water in, and flowing, through the bearing.
Replace it SOON.
Old 09-15-02, 02:57 AM
DoubleWhoosh
DoubleWhoosh's Avatar
You can wait until you can't put coolant back in fast enough to keep it topped off
It's gonna degrade pretty rapidly though!
Todd Matsubara
TM Engineering LLC
www.tmengineering.net
Old 09-16-02, 11:18 AM
GA400
GA400's Avatar
Post if it goes, you will be calling a tow truck
okfine,
My water pump went out about two weeks ago, a bearing seized, which made the timing belt continue to spin across the seized pump until it broke. End result? car no go no more.
Independent Lexus mechanic with all Lexus parts = 901.35 for new water pump, new coolant, new timing belt, new tensioners, seals and/or gaskets (can't remember which), new radiator shroud (old one was sagging and cracked before this), a cam guide (?) that got stripped when the timing belt went ka-blam, and quite a few hours of labor, and a tow truck.
Had I had it done pro-actively, it would have cost me a couple of hundred dollars less, at a minimum.
Regards,
GA400
Old 09-16-02, 08:18 PM
seanl
seanl's Avatar
If you've squeezed 223K miles out of your original water pump, then I'm impressed. Wow. Almost a quarter million miles.
Sounds like it's time to change it NOW though, you already know it's on the way out....why risk internal engine damage (from overheating) if you already know what's wrong....
Old 09-18-02, 10:15 AM
mlevk
mlevk's Avatar
Had mine replaced when the BELT was done.
IT's usually good idea to do it then , since everything else is off already and you are doing the belt as preventive mainteance.
You are just paying for the cost of the pump then.
I advise everyone the same when they do the T-Belt.
Mine was $750 , independent mech. OEM parts.
Bocatrip
07-04-16 04:10 PM
dejacky
Performance & Maintenance
12
12-22-09 08:17 PM
Och
09-10-07 09:30 PM
Sintari
08-26-07 07:10 PM
Quick Reply: ls 400 water pump
