1998, Rear End Clunk
Old 05-07-10, 12:40 PM
black_LS
black_LS's Avatar
Default 1998, Rear End Clunk
There's a heavy metal on metal clunk that comes from the rear end (diff, drive shaft?).
From park, when I shift into reverse, it clunks. If I go back into park and again into reverse (a second try), it won't make a sound. If the car moves in between the tries it will sound, but not as loud. Also does it in drive sometimes.
It is a very heavy metal clunk that happens when the gear engages. The severity seems to depend on whether the car is on an incline or not.
I know it's not the transmission mount since it was changed recently and the sound is coming from the back.
Any ideas?
Old 05-07-10, 02:55 PM
Thermactor
Thermactor's Avatar
check the driveshaft out. there are some rubber parts on it that fail with time.
Old 06-07-10, 11:20 AM
black_LS
black_LS's Avatar
The guibo looks good to me.
The sound is louder when the car is on an incline. It's becoming progressively louder and sounds very metal on metal.
Any ideas?
Old 06-07-10, 04:41 PM
JimsGX
JimsGX's Avatar
Best thing to do is get the car up on a drive-on lift, raise it way up and stand under there while someone shifts the vehicle with the car running. Should become apparent where the noise is coming from.
Old 10-21-13, 11:19 PM
black_LS
black_LS's Avatar
Though I would update this thread...
I figured this one out a couple years ago. It turned out the rear left axle was bad. 95-00 are all interchangeable.
Old 10-21-13, 11:39 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
thanks for updating, but the axle nut itself?
Old 10-21-13, 11:48 PM
black_LS
black_LS's Avatar
It was the CV Joint in the axle - I don't remember if the inner or outer was bad.
Also, the right side axle is a hair longer than the left. I ended up buying one from a yard, but they sent the wrong side. On second attempt, I got the correct side, but the ABS teeth were slightly deformed. I tried it regardless, and it caused my ABS light to come on at high speeds. Inspect your replacement thoroughly!
Hope this helps someone.
Old 10-22-13, 12:39 AM
RA40
Super Moderator
RA40's Avatar
Thanks for updating us. How many miles on car at the time? Was there any direct damage like some impact that might have caused this? Possible boot damage allowing road girt to be a factor?
Old 10-22-13, 07:26 PM
black_LS
black_LS's Avatar
The car was at roughly 135k miles. No damage from an accident or anything like that. The rubber boot was intact.
Old 10-23-13, 11:26 AM
timmy0tool
timmy0tool's Avatar
doesn't toronto see snow? i'm on 156k on the original axles, but i see the boots wearing out faster in other climates than others. regardless thanks for the update, even if it was 3 years later .
Old 10-24-13, 10:12 PM
black_LS
black_LS's Avatar
Toronto definitely sees snow, but the car hasn't been winter driven for many years.
Also, there was no audible clicking from the axle, like they usually do when they go bad - only the clunk described above.
CobraGSF
GS F (2016-present)
12-01-16 05:43 AM
KtIS
07-23-14 08:05 AM
RudyRC51
06-24-10 01:42 AM
Shaffer
02-12-04 09:26 AM
tsai423
10-10-03 05:08 PM
Quick Reply: 1998, Rear End Clunk
