longer wheel studs needed
Old Jul 16, 2009 | 12:02 PM
python's Avatar
python
Default longer wheel studs needed
so i am trying to find longer studs to get more clearance, any ideas on where to get them and spacers? thank you
Old Jul 16, 2009 | 12:42 PM
Ursus's Avatar
Ursus
Mackin industries retailers of volk rims have kics spacers. They have the lugs built into the spacer.
Old Jul 16, 2009 | 01:02 PM
python's Avatar
python
nice...ty!
Old Jul 16, 2009 | 02:01 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
project kiks or ichiba.
unfortunately the thinnest adapter available is ~15mm.
if you really just want extended studs, to run say a 5-10mm spacer, you can use the ARP studs made for the IS300.
Old Jul 16, 2009 | 02:03 PM
BLKonBLK98's Avatar
BLKonBLK98
those project kics aren't hub centric without spending the extra ~$50 on rings. if you're looking for 20mm+ i would go h&r or eibach. if you are looking for <20mm pressed stud type then the kics might be the best bet (w/ ring). ichiba also makes <20mm with studs, but their studs are on the soft side from what i understand. also, the <20mm studded type only work with certain wheels with clearance on the pad.
Old Jul 16, 2009 | 02:14 PM
BLKonBLK98's Avatar
BLKonBLK98
kics makes a 10mm pressed stud spacers, but the wheel pad clearance issues apply. adapters change lug patterns.
Old Jul 16, 2009 | 02:26 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
u can get hub rings here for 30. https://www.clublexus.com/forums/clu...et-wheels.html
Old Jul 16, 2009 | 03:01 PM
python's Avatar
python
i went to mackins website,they have 3 mm spacers, i am trying to get them on the phone right now...thanks guys
Old Jul 16, 2009 | 03:16 PM
BLKonBLK98's Avatar
BLKonBLK98
3mm? lol. you probably won't even need extended studs for that.
mackin is a distributer only last timed i checked. maybe they do retail now.
Old Jul 16, 2009 | 03:20 PM
Mugen_1's Avatar
Mugen_1
CL Folding 100,000
You can get cheap ones at Advance Auto Parts too; it's where I got mine. Some tire shops can order them as well. I needed 1/8" spacers: $20 for two from Advance and $32 for "tuner lug nuts" from AutoZone.
Old Jul 16, 2009 | 03:43 PM
PureDrifter
BahHumBug
CL Folding 100,000
you only need extended studs for spacers >3mm
so 3mm is fine.
Old Jul 16, 2009 | 03:48 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Originally Posted by LiCelsior
Not the same type of rings that make the KICS spacers hub centric, but they are used on top of those same rings.
Old Jul 16, 2009 | 05:48 PM
python's Avatar
python
i am getting these after i found out they were available,i was only able to find 1/4 inch spacers so i didnt feel comfortable with that much of the stud being hidden behind the spacer
Old Jul 16, 2009 | 05:55 PM
Mr.Euro's Avatar
Mr.Euro
serious? i work at advance. heh, i might order some tomorrow.
Old Jul 16, 2009 | 08:19 PM
Mugen_1's Avatar
Mugen_1
CL Folding 100,000
Yeah, I called my local store and they said it wasn't something they stocked, but could custom order through a supplier. They ordered mine (wrong size, though), had it in a week (after they spent four days forgetting to order it).
In the end, my tire shop ordered them :P
