longer wheel studs needed
Old Jul 16, 2009 | 08:43 PM
trukn1's Avatar
trukn1
NELOC Mod
Originally Posted by Puredrifter
if you really just want extended studs, to run say a 5-10mm spacer, you can use the ARP studs made for the IS300.
I ordered these and still have yet to install them. Was trying to wait until I got my CDS rotors and pads, however had to put some mods on hold for awhile. Unemployment really sucks.
Old Jul 17, 2009 | 12:11 AM
skperformance's Avatar
skperformance
What do you want the spacers for ? brakes or fitment ?
I have both H&R and Kics with its hub ring .
I prefer the H&R much better design and easier to work around.
Kics are ok but at 15mm will not clear most wheel hub surfaces.
I know what you mean trukn being out of a daily sucks.
Old Jul 17, 2009 | 05:49 AM
python's Avatar
python
i need want a little clearance between my calipers and rims,just in case a bearing starts to go or something,right now i have the slightest amount of room
Old Jul 17, 2009 | 11:31 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
3mm will be fine.
Old Jul 17, 2009 | 11:32 PM
skperformance
3mm is fine and almost every wheel shop carries them for less than $10.
Old Jul 23, 2009 | 03:17 AM
YOO's Avatar
YOO
Originally Posted by BLKonBLK98
those project kics aren't hub centric without spending the extra ~$50 on rings. if you're looking for 20mm+ i would go h&r or eibach. if you are looking for <20mm pressed stud type then the kics might be the best bet (w/ ring). ichiba also makes <20mm with studs, but their studs are on the soft side from what i understand. also, the <20mm studded type only work with certain wheels with clearance on the pad.
im just curious.. how are your wheels going to fit when your original studs are sticking out past the surface of the spacer? i dont see how the original studs will allow your wheels to sit all the way in...
please... can someone point this out to me...
thanks
Old Jul 23, 2009 | 03:45 AM
Jewel707's Avatar
Jewel707
thanks
Also are the Ichiba bad? I ordered some 5mm spacers with the replacement studs...i want to be on the safe side and make sure they're strong enough.
Old Jul 23, 2009 | 05:46 AM
PureDrifter
BahHumBug
CL Folding 100,000
all companies selling "adapter" style spacers (aka "bolt-on") specify that the WHEEL itself must have indentations/cutouts on the hub to give the old studs a place to go.
so double check your set of wheels and make sure it has these before ordering.
Old Jul 23, 2009 | 05:47 AM
PureDrifter
BahHumBug
CL Folding 100,000
ichiba's aren't "bad".
there have been MAYBE 1-2 people i've seen/heard about on these forums talking about snapping some studs. then again, i've seen/heard dozens of people snap OEM and ARP studs too, so i don't really think its a problem.
Old Jul 23, 2009 | 11:54 AM
Jewel707's Avatar
Jewel707
Good to hear. Thanks for clearing that up.
JDW379
Jan 30, 2014 04:53 PM
LilMan23
Feb 9, 2011 02:28 PM
eYezs1ck
Oct 8, 2010 09:10 AM
myke441990
Oct 5, 2010 10:00 PM
juguryan
May 12, 2007 08:27 AM
