Dropping your car causing clunking?
BahHumBug
ok look buddy, i not only helped you despite your attitude, i was relatively polite about it all. you came to this forum, broke the number two forum rule of SEARCHING, then broke the number ONE forum rule of NOT DISSING THE LOCALS.
actually go to the website i gave you instead of acting up and just expecting people to spoon feed you answers.
i am done with you. good luck.
Just look under your car. Trans mount = transmission mount, a transmission mount is a rubber piece that holds the transmission to the chassis without transmitting vibration to the chassis.
So look around the transmission for a piece of rubber that supports it, and maybe it'd be on the bottom, in the back.........just a hint...
Test that mount, and if it's good, then it's your driveshaft bushings, there's one on the transmission end, and one on the differential end.
it doesn't get much easier than the info you've been given.... get under the car and look around. that's the only way to be 100% sure of a diagnosis, nobody over the internet is going to be able to guarantee you anything. cars are like human bodies...one symptom can have several causes.
Jitters
adl16v
Performance & Maintenance
01-05-12 10:25 PM
supercoupes
05-07-03 10:11 PM
