LS1 HID Conversion cutoff lines
Old Mar 16, 2008 | 01:25 PM
  #46
Ross LS400's Avatar
Ross LS400
Ok, here are the pics as requested.
Firstly, Python, I still get my high beam indicator light on the dash and also have the separate high beam lamps illuminated as well as the higher angle on the HIDs. Mine is a 96 car and the headlamps are different from your 92 model.
These photos were taken against a metal garage door, probably not the best idea as its pretty reflective.
First one is low beam..............
Next, high beam. You can see the difference in colour temperature between the HIDs and the halogen type main beam only bulbs that are fitted to the original headlamps. I've left my main beam bulbs fitted as the lift between hi and low on the hids is significant so the halogen hi-beams in conjunction with the hid hi-beams give massive light out put on high beam. You may not be able to do this on a pre 95 car but it works wonders on the 95-97 series 3.........
Lastly, this one is against a wooden fence for slightly better definition........
Hope this is helpful.
Quick edit, here's one going back into my garage.............
Old Mar 16, 2008 | 02:13 PM
  #47
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
its pretty good considering the light is going through the light-dispersing lens but still not up to par with an OEM reflector or projector setup.
im waiting on the guy who used tealights
Old Mar 16, 2008 | 02:40 PM
  #48
Ross LS400's Avatar
Ross LS400
I could agree with that.
Old Mar 17, 2008 | 06:23 PM
  #49
dfkd's Avatar
dfkd
That's a really good beam. Definitely better than mine because mine lets a bit more light out moving upward. Not an intense beam but a kinda light leakage of light.
I'd definitely be interested in seeing the type of bulb and shielding that created that beam but then we do have to take into consideration the fact that you're in the UK and thus have what might be the best lenses made for these cars.
Old Mar 17, 2008 | 06:48 PM
  #50
97-SC300's Avatar
97-SC300
the cutoff line wont be that clean unless you retrofit with projectors.
Old Mar 17, 2008 | 07:05 PM
  #51
PureDrifter
BahHumBug
CL Folding 100,000
wont be that clean regardless they have fluted glass lenses, you cant sand them down like you SC guys can.
Old Mar 17, 2008 | 10:51 PM
  #52
NJ240sxMan's Avatar
NJ240sxMan
CL Folding 25,000
I wish we had some place that could make a clear glass lense replacement for the fluted lense anyone in for a GB? lol
EricOrtiz
Jul 19, 2011 11:58 PM
canvecchio
CT 200h Model (2011-2017)
Apr 20, 2011 07:23 PM
NAZTY97
Lighting
Jan 28, 2007 12:13 AM
GammaLex
Lighting
14
Jun 25, 2003 06:05 PM
ISDINGDONG
Lighting
17
May 2, 2003 10:37 PM
