LS1 HID Conversion cutoff lines
Old Mar 3, 2008 | 04:58 PM
dfkd's Avatar
dfkd
The bulbs I have are Hi/Lo but as far as i've seen, the high beems on those are always pretty bad.
They still work fine but they're pretty dim like they always were.
Old Mar 3, 2008 | 05:07 PM
Och's Avatar
Och
The high beam on my HID conversion is so bad, i even regret getting it in the first place, i should've just gone with single beam. The high beam with these is so useless and dim, its not even funny.
Old Mar 3, 2008 | 05:19 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
OCH any pics of ur car? mightve seen ur car around NY.
Old Mar 3, 2008 | 07:32 PM
Suneet's Avatar
Suneet
WHat about those dual bulb kits I've seen? The high beam bulb is a regular halogen? IS that what you guys have?
Old Mar 3, 2008 | 08:18 PM
dfkd's Avatar
dfkd
That's what I have as can be seen in the shot taken from below the bulb.
Old Mar 3, 2008 | 09:14 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
yea, most dual xenon kits are worthless, with HID you rarely use the high beams anyways
Old Mar 4, 2008 | 12:24 AM
Suneet's Avatar
Suneet
Not if you live out here in Seattle where you often find yourself driving straight up in the boonies... high beams are important.
Old Mar 4, 2008 | 01:45 AM
PureDrifter
BahHumBug
CL Folding 100,000
no, i mean that the hid brightness is much brighter than the high beams, just aim the headlights a touch higher?
Old Mar 4, 2008 | 03:09 AM
Caoboy's Avatar
Caoboy
Don't worry. With a PnP HID kit, your highbeams will be on constantly.
Good luck with the cutoff. It won't ever be good enough though, no matter how hard you try. Also try blacking out the shields, so that the light won't be reflected as much. You want as little as possible reflection...the fluted lenses don't help either. If you could somehow get the JDM headlights, and the super rare clear covers, then a retro fit would be the best way to go.
I have seen on HIDplanet a couple people who have retro'd in projectors behind the fluted lenses. It was not TOO bad of a cutoff line, definitely better than what you have right now.
Old Mar 4, 2008 | 08:54 AM
PureDrifter
BahHumBug
CL Folding 100,000
the JDM clear lenses were made by HilTop and never really came out great esp. when the price was in the $500+range.
since the 93-94 and JDM models used H4 bulbs, wouldnt a casper shield be fine?
Old Mar 4, 2008 | 01:27 PM
Ross LS400's Avatar
Ross LS400
I have an Otto H4 HID kit fitted to my '96 LS400. Cutoff is great and high beam is excellent. It works in a totally different way to most H4 kits I've seen.
The bulbs have sliding shrouds and there is an electro-magnet on the rear of the bulb holders. When you flick to high beam, the magnets reverse polarity and slide the shrouds back causing the whole beam pattern to raise to a higher level. Its very effective, definitely the best system I've come across.
Old Mar 4, 2008 | 04:31 PM
dfkd's Avatar
dfkd
Those bulbs work great because when they are in low beam mode the bulb is actually properly shielded.
Those ones work like this...
Old Mar 4, 2008 | 09:18 PM
nosechunks's Avatar
nosechunks
So why dont people use these in our cars? Im guessing they dont make a 9006 style?
Seems like it would work, would it not?
Old Mar 4, 2008 | 09:37 PM
PureDrifter
BahHumBug
CL Folding 100,000
huh? why would u need dual xenon on a 9006 setup? and 'sides, your 94 uses H4 headlights, not 9006.
Old Mar 5, 2008 | 08:07 AM
Ross LS400's Avatar
Ross LS400
dfkd,
Yes, they are very similar to the ones I have. Definitely the best headlamps I've had in any of my cars. The other plus with these ones is that they work using a relay harness taking power direct from the battery and switching authority from one of the original headlamp harnesses, the other original headlamp harness remains unplugged. That way, the power to the ballasts is not momentarily interrupted by the original headlamp relay when you switch to high beam. This should extend the life of the ballasts and bulbs quite considerably.
