LS400 owners post your wheel setup
LOL.. Personally paulo I hate the bmw 7 series wheels. Id run the m5 wheels just to be different. Just odd cross platforming wheels. But hey, thats just me..
Also a 9" +0 in the front is cake. Those are baby sizes. Just get all your fenders rolled around to get started. Do not shave if you ever plan to pull. The inner lip is required to keep strength in the fender for the pull. The fender roller(guy doing your fender work) should/will still shave alot of the inner lip, but leave enough for extra strength should you need to pull later for wider wheels.
91 ls400
20x8.5 Armano Maybach wheels
Falken FK452 tires
don't know offset, sorry!
stock suspension!
Posted from ClubLexus.com App for Android
Falken FK452 tires
stock suspension!
Originally Posted by JBls400
91 ls400
Falken FK452 tires
stock suspension!
Falken FK452 tires
stock suspension!
I'm looking to run 19x9 + 13 on 225/40 & 19x10 +12 on 255/35 real soon.
I'm also tryin to avoid body work at all cost... Will I have to shave & roll the fronts at this size ? As for the rear with this set up, can I get away with rolling the lip or will it have to be shaved ?
1998 LS400
Weds Kranze Rapiers
F 19x10 +15 Ventus V12 225/35/19
R 19x11 +15: Ventus V12 245/35/19
Ksport Kontrol Pro Coilovers
H&R 10mm spacers in the front to clear OEM brake calipers
Megan rear lower camber, toe and traction links.
Weds Kranze Rapiers
Whats the specs of the alignment? How much camber you running front and back?
