Seat Memory quit?
just tap the buttons quickley about 100 times. the conections somtimes corrode so when you press the buttons alot it reconnects them somehow. Make sure to check fuses too!
I know it sounds crazy but i had the same problem. Totally worked.
make sure that u arent pressing the brake, are in PARK (not neutral or anything else). also, if u reset the ECU (disconnected battery) then ur settings were lost and pressing the 1&2 buttons won't do anything, you have to store them again.
