Power steering pump locks up
Old Jun 3, 2025 | 12:01 AM
Scartcelsior's Avatar
Scartcelsior
5th Gear
Default Power steering pump locks up
New to site here. Have a 1992 Toyota Celsior and when I replaced power steering pump and putting pulley on, it locks up the pump like no spinning. This was the last thing to get it going! 🙄 Am I missing something?
Old Jun 4, 2025 | 09:48 AM
Lexus1uz's Avatar
Lexus1uz
What brand of pump did you use? What was the reason for replacing it?
Old Jun 5, 2025 | 04:18 PM
Scartcelsior
5th Gear
Default Lares pump
Talked to Lares and they questioned the diameter of the old pump shaft. The old pump was probably original JDM and I bet it’s different than Lexus LS400 replacement pump. Anyone have an original LS400 power steering pump pulley they don’t need?
Old Jun 6, 2025 | 03:52 PM
Scartcelsior
5th Gear
Default Didn’t answer your question sorry
Realized I didn’t answer your question. Notorious leakage figured if I was going to have to pull pump anyway might as well replace with new. Thought about rebuilding but glad I didn’t try now seeing as most rebuild kits would be for Lexus not Celsius.
Old Jun 9, 2025 | 09:22 AM
CELSI0R's Avatar
CELSI0R
Well, here's the thing. The Celsior and LS 400 power steering pump and pulley are the same
https://www.amayama.com/en/genuine-c...0/chassis/4502
So the question is more if the rebuilt unit you got is good or how the parts were reinstalled. Pictures would help
Maybe your pulley was not pressed on properly? Maybe the bearing for the pump shaft is no good?
Did the shaft spin on the new pump before you installed it onto the car?
Old Jun 18, 2025 | 12:04 AM
Scartcelsior
5th Gear
Default New pump
Pump is new. Reinstalled pulley on old pump spins no problem. Install on new pump locks up. Meaning locks up against the pump. Pulley off of new pump, pump spins freely. I hate to have to buy another pump and pulley from junkyard just to get the pulley hoping that is the problem
Old Jun 19, 2025 | 04:32 AM
CELSI0R's Avatar
CELSI0R
Sounds like something is wrong with the way the new pump was rebuilt. Can you post some pictures, please?
That shouldn't be an issue when you're pressing the pulley on the same way to a new pump as it sat on the old pump. It sounds like the shaft on the new pump may not be properly aligned. Does the pulley make contact with the pump housing when it's pressed on?
Old Jun 28, 2025 | 08:02 PM
Scartcelsior
5th Gear
Default So… I’m embarrassed
So upon further investigation, figured out pulley was hitting power steering hard line. 🤦‍♂️
MadHighMaca
Dec 26, 2023 05:34 PM
tritron
SC400 / 300 Classifieds
Apr 23, 2008 11:42 AM
etex
Jan 18, 2008 09:47 PM
Tymboo
Nov 13, 2006 08:44 PM
Brando
Aug 18, 2006 06:19 PM
