temperature gauge issue
Old Apr 18, 2025 | 03:59 PM
bobsls400's Avatar
bobsls400
6th Gear
Default temperature gauge issue
1998 ls 400 temp gauge go to hot after running 10 minutes . not losing cabin heat no smell of coolant . replaced thermostat did not help .
Old Apr 21, 2025 | 12:20 PM
timmy0tool's Avatar
timmy0tool
from your other post here, you are already looking at the cluster sensor which is the right path.
but are you sure you do not have any air in the coolant? has there been any recent coolant related work done to the car?
Old Apr 25, 2025 | 06:42 AM
bobsls400's Avatar
bobsls400
6th Gear
i believe i found my issue took belt weight of water pump belt and found movement in the pump
bruklein
Feb 28, 2024 08:19 AM
