LSD conversion kit?
Old Oct 17, 2024 | 04:22 PM
haydenadler1's Avatar
haydenadler1
Default LSD conversion kit?
Im looking into a LSD for my 98 Ls, and all I can is the commonly known supra diff swap. Those are expensive to find, and I can imagine would require a lot of work. I know LSD conversion kits exist out there, is there a reason I cant find any for my car? Theres plentiful for the IS, but none for the LS. Would it be possible? If it is, could I just have a machine shop make it?
Curious about this, thanks for the replys.
Hayden.
Old Oct 18, 2024 | 05:47 AM
GoldStar's Avatar
GoldStar
Been looking into this for a minute. There aren't any "kits" because you just need a set of bearings and an actual LSD gear set, which appears to be drop-in for the 98-00s if you get the right one. It can be done, check out Forward Momentum's videos on youtube for details on a CBS Racing helical diff gear set. We have the "bolted" diff, which makes things easier.
Old Oct 18, 2024 | 07:56 AM
haydenadler1
Okay, would a resistance pack not work? My buddy with a e46 zhp dropped in a resistance pack that mimics a LSD, all it consists of is some metal plates and some springs all put together. Does our diff design not allow for that?
Old Oct 18, 2024 | 10:28 AM
GoldStar's Avatar
GoldStar
You mean a clutch pack style diff? That's just the style of the gear set, it's still an LSD. I don't believe you can convert our stock open gear set to a clutch pack style, so you'd still be replacing it anyway. KAAZ sells a couple clutch-pack style diffs, I believe the DAT3020 and DBT3020 will fit:
https://www.clublexus.com/forums/ls-...-97-ucf20.html
https://kaazusa.com/product/supra-jz...5-way-dbt3020/
Old Oct 18, 2024 | 11:47 AM
haydenadler1
sorry, I shouldve been more specific with my description. Instead of “plates” I shouldve said bricks. I will include a picture, but if its not a good photo just search up LSD conversion kit. Thats what im talking about, and im curious if that would work with our differential style.
Billllak
Sep 28, 2022 08:21 PM
SCVito
May 6, 2022 06:13 PM
djpauldc1
Oct 29, 2010 12:28 PM
SC400DRFT
Sep 16, 2006 06:05 AM
LasVegasGS
Performance
21
Jul 28, 2005 07:42 PM
