1993 LS400 battery replaced, no lights and wont shift out of park
Old Sep 22, 2024 | 12:21 AM
Micheline's Avatar
Micheline
5th Gear
Unhappy 1993 LS400 battery replaced, no lights and wont shift out of park
OK, long story as short and sweet as I can make it. Started off with a weird battery drain, jumping it off about once a week, then the battery was less than 10 volts, so i tried another battery, ( I might have accidently reversed the polarity) it would only crank but not start so that didn't work, so I reconditioned and charged the original battery, put it in and it started right up....problem is no lights ANYWHERE, all I have is horn and hazards. It also wont shift out of park. I was advised to replace the 120 alt amp cartridge fuse. done. still no lights anywhere and I've called myself checking the other 3 fuses that it "could be", to no avail. I'm in no position to "throw parts at it, and I'm at a loss, PLEASE HELP.
Old Sep 22, 2024 | 02:06 AM
Yamae's Avatar
Yamae
A reversed battery will kill not only the 120A alternator fuse but also some other fuses. You need to check those.
Old Oct 7, 2024 | 10:23 PM
Micheline's Avatar
Micheline
5th Gear
I have replaced every fuse, I now have door/courtesy lights, the "key in ignition" buzzer. Still no dash, and head/tail lights and still wont shift out of park. Any other suggestions? what do I do next?
Old Oct 8, 2024 | 12:38 AM
Micheline's Avatar
Micheline
5th Gear
Old Oct 8, 2024 | 03:22 AM
Yamae's Avatar
Yamae
It is quite seldom but electronics circuits are sometimes damaged by the reversed connection.
Old Oct 8, 2024 | 03:47 AM
Micheline's Avatar
Micheline
5th Gear
Which ones? please.
Old Oct 8, 2024 | 04:31 AM
Yamae's Avatar
Yamae
Which ones? please.
It's hard to tell for me without analyzing the car myself using measuring tools such as an oscilloscope, a TDR, an ESR meter and others. Electrolytic capacitors are sometimes damaged by the low impedanced reverse voltage if applied long time and it is useful to use an ESR meter for the judgement.
Old Oct 8, 2024 | 05:03 AM
Micheline's Avatar
Micheline
5th Gear
I agree, but where to start? fuse boxes or ecm?
Old Oct 8, 2024 | 06:00 AM
Yamae's Avatar
Yamae
Using a TDR, I'd start to check related lines that supply the DC12V to the dash, head/tail lights and the shift control lines. It would be also useful to check the impedance of related lines comparing with a good working 93 LS400 for the reference.
Old Oct 9, 2024 | 01:20 AM
Yamae's Avatar
Yamae
Another important issue is that to check lines where fuses were blown. When you replaced every fuse, did you take a note which lines had blown fuses? Those lines are very important to check. Fuses need some mili-seconds to be blown. This simply means that the reversed voltage was applied some mili-seconds and this might kill some units.
Weltidave
CT 200h Model (2011-2017)
19
Nov 23, 2017 10:36 AM
katkatgre
Maintenance
Sep 3, 2017 01:17 PM
JiggsHall
Feb 10, 2016 09:05 AM
PlacidBoi
Aug 12, 2012 06:59 PM
