Coolant temps
Old Aug 3, 2024 | 10:09 PM
Ls400silver's Avatar
Ls400silver
8th Gear
Default Coolant temps
I’ve been trying to find out exactly what the car normally runs at and when it overheats in Fahrenheit. mind you I use a scanner to get my temps since my gauge has a mind of its own. I’m looking for temp in F not the usually 3rd bar or In-between, my car runs at 190 F to 199 F in my towns 90 to 100 F ambient temp I’m wondering if maybe the ambient heat is putting stress on the car or if I’m overheating.
also it’s a 1999 ls400 running proper mixed coolant. Water pump and timing belt replaced at 205k now at 239k. coolant flush, t-stat, rad cap and ect done at 239k. I’m looking for normal operating range in Fahrenheit and where you should be worried in Fahrenheit.
Old Aug 3, 2024 | 11:36 PM
Thermostat is rated at 82-95 degrees C. which puts your coolant temp exactly in specification. 'Stat starts to open at 82 starts and is closing at 95.
Old Aug 4, 2024 | 12:20 AM
Ls400silver
8th Gear
is hitting 220 F or 104C bad, during a heat wave of 115 ambient temp I was running my ac and the car got up to 220F or 104C before I realized and I threw the defrosters on max to cool it back down.
Old Aug 4, 2024 | 01:20 AM
I think 115 ambient is about the limit of the cooling system. Defrost doesn't cool the engine down that's not how the system works.
Old Aug 4, 2024 | 10:13 AM
cyfi66's Avatar
cyfi66
220f is fine if you start creeping to 230 then turn off the AC.
Old Aug 5, 2024 | 08:03 AM
Stroock639's Avatar
Stroock639
can you notice the coolant gauge ever actually moving? as long as it's sitting just above that 2nd tick mark you're totally fine (which is about 200°F)
also yea the defroster won't cool the engine (the opposite actually since it uses the A/C), for that you'd need to turn on the heat
Macdog6249
Oct 23, 2024 10:33 PM
M03
16
Apr 2, 2021 12:48 PM
terminater
Aug 24, 2017 05:43 PM
Bocatrip
Jun 2, 2016 02:37 PM
comrade904
Apr 23, 2009 07:22 AM
