What is the normal running coolant temperature?
Old Jul 8, 2024 | 12:39 PM
Macdog6249's Avatar
Macdog6249
Default What is the normal running coolant temperature?
Just started looking at coolant temp, where should it be under normal running conditions in centigrade?
Old Jul 10, 2024 | 07:56 AM
GregMN's Avatar
GregMN
OEM thermostat is 180F, 82C
With the bold line at the bottom, cold end. of the gauge, both my cars run at the second line up all the time, no matter the load or ambient temp. Note: I have not had the pleasure of driving in triple digit temps.
Old Jul 10, 2024 | 12:14 PM
dwoods801's Avatar
dwoods801
the thermostat opens at 180, but they can you to 220 before it's going to overwhelm the cooling fans and cause the gauge to climb above it's usual position. The gauge seems to be more of a warning light than a way to accurately reqd the temp. I have a thermostat built into my radiator cap and I have seen it get above 200 right after it was worked hard.
Old Jul 10, 2024 | 12:29 PM
chuyrobles's Avatar
chuyrobles
Ambient temperature is a factor, and temps vary a bit among same rated thermostats. The normal range for a 180 degree thermostat is 185-200 in my vehicles with a warmed up engine.
Old Jul 10, 2024 | 06:32 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
do you just want to know where the needle is sitting at normal operating temp?
Old Jul 11, 2024 | 03:14 AM
Macdog6249's Avatar
Macdog6249
Thanks for the responses guys.
I was using an OBD II reader which was giving me a coolant temperature of 100 C, the gauge is showing just coming off that second line. Just checking, I think I'm good, but will keep monitoring it.
Old Oct 17, 2024 | 02:30 PM
GregMN's Avatar
GregMN
82 degree day. A/C on. 65mph on the flat. Ultra Gauge reads coolant at 194 degrees. Drive up from 2200' to 5000' in 6 miles, 6% to 7% grade, with cruise set to 65. The coolant temp tops out a 212. In town traffic at the top of the hill, it runs about 199.
The dash temp "gauge" never varied during 18 degrees of coolant temp change.
Old Oct 17, 2024 | 07:30 PM
Someone028's Avatar
Someone028
Temp gauges are indeed more like an idiot light. To keep people from freaking out over the temp varying under different driving conditions, they simply set the "needle" to the middle for a fairly wide range of temps. Was able to turn this "feature" off in the Saabs I used to own. Haven't looked into it for the SC430.
Old Oct 20, 2024 | 07:25 AM
Seattle SCone's Avatar
Seattle SCone
My engine and transmission temps after 20 minutes at highway speed, flat terrain are 190 and 153 F.
These are in idle, immediately after parking.
Old Oct 20, 2024 | 04:08 PM
doobs's Avatar
doobs
Cool dashboard.
It's it possible to share it?
Old Oct 20, 2024 | 09:51 PM
Seattle SCone
Originally Posted by doobs
Cool dashboard.
I will see if I can export a configuration from Torque. I've never done that.
Old Oct 22, 2024 | 06:10 AM
doobs's Avatar
doobs
Thank you.
Old Oct 23, 2024 | 10:33 PM
Seattle SCone
Here is a link to zip of my Torque Pro layout.http://cosalient.com/picture/lexus/k...20pro.dash.zip
Otto87
GX - 2nd Gen (2010-2023)
Oct 10, 2023 05:16 AM
King0824
Aug 4, 2023 10:22 AM
Nyhof1
NX - 1st Gen (2015-2021)
Dec 20, 2022 03:34 PM
johnH03
Feb 28, 2022 06:24 PM
oo10inz
Nov 3, 2019 12:36 PM
