rear knuckle bushing?
Old Apr 9, 2024 | 06:25 PM
diedroopy's Avatar
diedroopy
Default rear knuckle bushing?
Does anyone know where i can get rear knuckle bushings, in store preferably but if i have to order i will. i cant seem to find them, im having a clunking noise from left rear side when going into drive so im going to try this first, but does anyone have any other ideas on what it might be?
Old Apr 9, 2024 | 06:49 PM
400fanboy's Avatar
400fanboy
They come pressed-in from the factory into the knuckle, and the knuckle's are out of production.
Febest used to make a rubber press-in bush replacement, but that's out of production and only some are left.
After that the only option is poly and the compromises that comes with.
Are clunk when going into drive is not a reason to just start hip firing bushings into the rear imo. My car has a dull thud too, from the driveshaft slamming pretty hard when the torque hits. Not any bushing moving.
Old Apr 11, 2024 | 01:36 PM
timmy0tool's Avatar
timmy0tool
have your confirmed it's actually the bushing? there are several bushings they could be, or even the sway bar endlinks.
i also hope you're not confusing a clunk noise with a brake noise, drivetrain (shaft or axles), or even engine/trans mounts although those don't make noise - they just completely break apart and cause vibrations.
Old Apr 15, 2024 | 01:19 PM
diedroopy's Avatar
diedroopy
so did end up getting the polly bushing because that’s the only one i can find, i put it in and it definitely needed it, it helped a lot but there is still a slight clunk coming from the rear end, i can see the diff move up, could it be that that’s causing the noise and movement? that’s the only other thing i can see
Old Apr 15, 2024 | 02:15 PM
400fanboy's Avatar
400fanboy
Clunk when what? Going between drive and reverse like here?
Old Apr 15, 2024 | 02:54 PM
diedroopy's Avatar
diedroopy
https://www.youtube.com/watch?v=BgZM03wWCi8
yes sort of like that, it’s moving like that but it sounds like a metal hitting metals type of noise. It only happens when’s going from Park to Drive and is a lot worse when the car is cold the bushings move like in the video
these are mine
Old Apr 15, 2024 | 03:59 PM
Losiracer2's Avatar
Losiracer2
how is your trans mount? that can deteriorate to the point of being metal/metal if all the rubber is gone
Old Apr 15, 2024 | 05:09 PM
diedroopy's Avatar
diedroopy
trans mount was horrible when i got the car, changed it about 2 months ago
rararames
Jun 8, 2023 08:10 PM
PandaGS300
Sep 21, 2015 05:33 AM
skeletor
May 8, 2012 11:02 AM
ce5288
RX - 1st Gen (1999-2003)
Dec 28, 2009 05:50 AM
hobojoe
Sep 22, 2009 05:59 PM
