Key fob program
Old Aug 29, 2023 | 04:15 PM
Dejablu's Avatar
Dejablu
10th Gear
Default Key fob program
Programming my LS 400 to a key fob. Car goes into program mode fine. No matter what sequence of buttons that I hit afterwards, the car beeps immediately and will not accept the fob. I’m on fob #3. It’s actual Lexus key fob.
car will go into program mode but doesn’t want to program to any fobs.
Old Aug 30, 2023 | 03:42 AM
Yamae's Avatar
Yamae
Do all door actuators work perfectly?
Old Aug 30, 2023 | 04:38 AM
Dejablu's Avatar
Dejablu
10th Gear
yes, all actuators work perfectly
Old Aug 30, 2023 | 10:22 AM
paulo57509's Avatar
paulo57509
Can you reference the programming procedure (or procedures) you're using? It would save time for the rest of us trying to help you figure this out.
Old Aug 30, 2023 | 11:45 AM
Dejablu's Avatar
Dejablu
10th Gear
[QUOTE=paulo57509;11569109]Can you reference the programming procedure (or procedures) you're using? It would save time for the rest of us trying to help you figure this out.[/
INSERT the key into the ignition and PULL it out.
LOCK and UNLOCK the door lock switch 5 times.
CLOSE and OPEN the DRIVER'S side door.
LOCK and UNLOCK the switch
Switch the ignition to ON then OFF TWICE
REMOVE the key from the ignition.
The door locks cycle to confirm successful entry into programming mode.
Here is where my car acts crazy
Supposed to happen
PUSH and RELEASE the LOCK and UNLOCK button on fob. As soon as you let go PUSH and HOLD the lock button on the fob for 2 seconds. The door locks will cycle to confirm successful programming of the remote.
What happens
PUSH and RELEASE the LOCK and UNLOCK button on fob, the door locks immediate cycle and I never get to PUSH and HOLD the lock button.
Fob does not program. And I have tried just pushing the lock alone and no difference. The locks cycle as soon as I hit any key on the fob and the programming does not take place. I am trying my 3rd fob. This one is an actual Lexus. Car does the same with all 3.
LexusQ
NX - 2nd Gen (2022-current)
106
Oct 26, 2024 10:51 AM
Chelsea92
Jan 24, 2023 08:38 AM
damns0n
GS F (2016-present)
Oct 6, 2021 11:06 AM
RonK
IS C
Feb 1, 2021 06:43 PM
