Weird steering wheel alignment issue
Old Jul 30, 2023 | 02:09 PM
Lexus1uz's Avatar
Lexus1uz
Default Weird steering wheel alignment issue
Hello everyone,
I'm having a strange steering wheel alignment issue with my 98 ls400. After I make a few left hand turns the steering wheel stays crooked to the left, when I make right turns it seems corrects itself. I checked my inner/outer tie rods, upper control arms, lower contol arms/ball joints and all seem fine. The car does not pull to the left or right. There is no play with either wheel when the car is jacked up. The steering rack is smooth and was replaced about a year ago and the car had an alignment and lower control arms replace 3 months ago.
Could the steering rack be going out again? Has anyone had this issue?
Any help will be greatly appreciated.
Old Jul 30, 2023 | 05:48 PM
paulo57509's Avatar
paulo57509
Things to check in this order:
  1. Tire inflation pressure.
  2. Alignment.
  3. Binding steering column.
  4. Steering gear.
My '98 has a pretty "soft" return to where I have to turn the steering wheel back after making a turn. But it's not biased to any direction. I always thought it may need more caster dialed in.
Old Jul 30, 2023 | 06:14 PM
400fanboy's Avatar
400fanboy
I have always found I like having more positive caster and toe in. The steering feel is quite boosted and easy, but, it should still want to return to center. Requiring you to turn it back is abnormal (to how many car operates).
As for the alignment - is the rack itself maybe moving? If the rack mounts were rotting away perhaps that could introduce an ability for the rack to just suddenly shift to one side.
Old Jul 30, 2023 | 06:19 PM
Lexus1uz's Avatar
Lexus1uz
Paulo, thanks for your reply. The tire pressure is good and steering column is smooth. I think it's either the rack or strut rods. The strut rods is the only front suspension part that is original. They don't move and aren't cracked but the large bushings seem to be deformed. They don't seem to be that bad but I guess it could affect the steering. It's just weird how the steering wheel is only affected when I make a left turn and is find when I make a right turn.
Old Jul 30, 2023 | 06:21 PM
400fanboy's Avatar
400fanboy
The strut rods are a known wear item. Typically one of the first suspension components that's replaced. They usually fail around 100k miles and you can tell on the test drive if you're front end feels very loose over bumps. It can also cause a slight vibration when going 60-65 mph or a shimmy under light braking from highway speeds that will be felt in the steering wheel instead of in the pedal like warped rotors normally would. You can also experience a "clunk" when you hit the brakes at low (parking lot) speeds.
Old Jul 30, 2023 | 06:23 PM
Lexus1uz's Avatar
Lexus1uz
Fanboy400 tomorrow I'll check the rack bushings for wear or play. I have owned the car for a while and have put on many miles. It's not an issue with the return rate. If I hold the wheel straight I'll veer to the right
Old Jul 30, 2023 | 06:30 PM
Lexus1uz's Avatar
Lexus1uz
My strut rods are original 300k miles. I don't have any vibration or shudder at any speed. I am going to replace them and check the rack bushings. I replaced the rack about a year ago so I am hoping it's not that but being a reman anything is possible.
Old Jul 30, 2023 | 06:36 PM
400fanboy's Avatar
400fanboy
I'm surprised they've lasted that long, that's wild. They normally fail very quickly.
However, I do think they're unlikely to be the cause.
Old Jul 30, 2023 | 06:51 PM
Lexus1uz's Avatar
Lexus1uz
I think mostly highway miles has played a big part to the longevity of the suspension parts.... and no salt!
Old Jul 30, 2023 | 10:24 PM
cj98ls's Avatar
cj98ls
I wonder if one of the adjustment cam bolts are coming loose and change alignment when the steering wheel is turned. Maybe a missing cotter pin?
Old Jul 31, 2023 | 09:49 AM
Losiracer2's Avatar
Losiracer2
If it feels like your rear end is very unpredictable, then you likely also have bad rear knuckle bushings. There's a floating rear bushing that can get a lot of slop in it. Febest makes them for $18 each on Amazon and they press right in/out with a C-Clamp tool. I've used their Front LCA bushings and they're decent quality.
Old Jul 31, 2023 | 01:28 PM
400fanboy's Avatar
400fanboy
Quite the complete set they have
Old Jul 31, 2023 | 02:37 PM
timmy0tool's Avatar
timmy0tool
this is my vote; that the rack is moving due to bad/compromised mounts. this would be my first check.
Old Aug 1, 2023 | 08:37 PM
cj98ls's Avatar
cj98ls
Was watching Youtube this eve and stumbled across this vid by the CarCareNut. In particular starting at 20 minutes in...
It looks like 400fanboy got it right on.
Old Aug 1, 2023 | 11:09 PM
400fanboy's Avatar
400fanboy
You know what's hilarious, I learned of it PRECISELY from that video 🤣🤣🤣🤣🤣🤣
I'm like oh, wait a minute, that sounds like what I just learned about in this video! What goes around come around.
