Sponsored by: CARiD
scratching head (noob question)
Old Mar 15, 2020 | 01:14 PM
nymantis's Avatar
nymantis
Default scratching head (noob question)
i apologize if this a super noob question or of this has been a topic already , but i can't seem to find the answers im looking for. Ok so my headlight top mounting braket broke on both headlights. i found this out because i started to notice water droplets in the case, then my right headlight started to flicker followed by the check headlight warning. i took out the headlights and blew dried them. After that i epoxied the top tabs.Now i can't seem to find anything on how to replace bulbs lmao. i've never owned headlights like these so I'm a bit confused. I figure for future reference in case i ever need to replace ill know, but i cant seem to figure out these headlights. here are some pictures of the headlights. i have 2014 is 250 f sport
this is the top tab that broke
this the top tab that broke
where is the bulbs?
Old Mar 16, 2020 | 05:08 PM
nymantis's Avatar
nymantis
ok so that epoxy didn't hold up at all, it broke right away. So i said F it and just gorilla taped the hole from the tabs breaking off. Now the light are working fine, but the check headlight warning is still on. I realized the level was off so i adjusted them and made the even as possible thinking maybe that was the reason for the warning. Nope! still on, now I'm out of ideas on what it could be. does the 3rd Gen IS250 F Sport have a left and right adjustment? i don't see anything on the housing or am i missing something because i don't see anything on the web. Can some please help me.
this is what i adjusted them to.
Old Mar 23, 2020 | 02:45 AM
Matroushi's Avatar
Matroushi
Not sure how to get rid of the warning but the headlights you have are LED, and as far as I know, you can't change the bulbs.
Old Aug 1, 2020 | 12:47 PM
B00M3R's Avatar
B00M3R
To get rid of the code, you need a OBD2 code reader, you could also go to a local auto parts shop and they should be able to clear the code depending on what it is and what is causing it.
Old Jan 27, 2021 | 05:43 AM
Tank's Avatar
Tank
Can you post a pic of the warning light?
Sometimes on certain cars you can use a jumper wire to reset different lights.
MrBruin09
Mar 31, 2012 05:02 PM
kams229
Sep 30, 2008 03:54 AM
timucla
Feb 4, 2008 08:32 PM
Dr. VIP
Jun 20, 2007 07:13 AM
ShowGSLuVv
May 14, 2002 04:34 PM
