Sponsored by: CARiD
Philips 6000k Ultinon HID Install Question??
Old Jul 24, 2003 | 08:36 PM
CaMsGS3's Avatar
CaMsGS3
Default Philips 6000k Ultinon HID Install Question??
Sup Guys, I just have a question about installing this kit,
In the pic below im pretty shore i labeled everthing correct as to where its suppose to go. The only problem i see is that Im not sure where the white plug goes(the one circled in red)Im thinking that it would plug into one of my OEM headlight connectors-but ive been reading the DIY on CL and all the kits have 2 of these white plugs so i can plug them into both of my OEM headlight connectors(one on each side), why would this kit only have 1, Im i missing something??
I know the pic isnt that clear but does everthing seem labeled correct
Thanks
Attached Thumbnails Philips 6000k Ultinon HID Install Question??-hid-medium-.jpg
Old Jul 24, 2003 | 08:59 PM
rominl's Avatar
rominl
exclusive matchup
well the diy was done by me, i had the old kits where it uses both connectors, but i heard some new kits only use one?
Old Jul 24, 2003 | 11:30 PM
PHML's Avatar
PHML
Master Thread Closer!!
This wiring setup is really messed up.
Maybe it takes only 1 OEM 9006 socket connector (circled white one) to trigger both ballasts.....thats the only thing i could think of. Try it.
Good luck.
Pete
Old Jul 24, 2003 | 11:36 PM
CaMsGS3's Avatar
CaMsGS3
Yea thats what i was thinking, ill try it tommorrow
On the instructions that white plug is labeled "Power Output for HeadLamp"
Old Jul 24, 2003 | 11:53 PM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Before you test the kit, make sure the bulb is connected to the ballast or else you will fry it.
Old Jul 25, 2003 | 12:43 AM
PHML's Avatar
PHML
Good tip...and dont forget to cross your fingers.
PS....check the 15 amp fuses if it doesnt work...NOT the 20 amp on the wiring setup.
Old Jul 25, 2003 | 08:26 AM
rominl's Avatar
rominl
exclusive matchup
the 15a fuse for my headlights are ok. but the 15a fuse for my fogs blew when i put in my hid fogs. a 20a did the trick.
Old Jul 25, 2003 | 02:18 PM
slawek's Avatar
slawek
white plug goes to only one OEM conector. I have same kit, works perfect.
Old Jul 25, 2003 | 06:15 PM
CaMsGS3's Avatar
CaMsGS3
Thanks guys for the info, I finally installed them today took me ONLY 20 Minutes to do, very easy to install
WOW-What a difference, I will never go back to halagons again
Anyone who wants a kit can email dtpstyle@yahoo.com I beleive he still has a couple left
Old Jul 25, 2003 | 06:57 PM
rominl's Avatar
rominl
exclusive matchup
congrats man, welcome to the club
Old Jul 25, 2003 | 10:04 PM
Wald GS's Avatar
Wald GS
Glad everything worked out for you PHIL!! This mod is the difference between night and day!!
Old Jul 25, 2003 | 10:06 PM
Wald GS's Avatar
Wald GS
Post some pics PHIL!!!
Old Jul 27, 2003 | 06:22 PM
Wald GS's Avatar
Wald GS
Just a reminder to post some pics.
upstateGS4
Apr 12, 2006 01:01 AM
GSquicksilver
Lighting
May 3, 2004 10:42 PM
cheapsk8
Lighting
Mar 31, 2003 04:39 PM
ezlyf
May 9, 2002 09:36 PM
TDGS300
Oct 5, 2001 03:43 PM
