Sponsored by: CARiD
D2r Vs. D2s
Old Apr 16, 2003 | 04:27 PM
ISDINGDONG's Avatar
ISDINGDONG
Default D2r Vs. D2s
does anyone know if you can just replace the oem d2r bulb with a d2s bulb?
need to know if the difference is in the light shielding only, d2r has a metal shielding inside the arc. to produce a sharp cut off and the d2s has no metal shielding in the arc.
can a oem d2r bulb be replace with a d2s bulb by just switching out the bulbs only?
any information or input will be appreciated.
Old Apr 16, 2003 | 06:24 PM
PHML's Avatar
PHML
Master Thread Closer!!
Sure it can.....just make sure that the D2S base fits your housing and the connection to the ballast.
Pete
Old Apr 16, 2003 | 06:33 PM
rominl's Avatar
rominl
exclusive matchup
the base is slightly different. they have a little **** on different side of the base from certain angle. at most you will just need to use dremel to cut out a little piece of d2s and it will fit in d2r housing
but my question is, why? you are not lighting up the road more, you are just blinding the oncoming traffic more
Old Apr 19, 2003 | 03:08 PM
gs400998's Avatar
gs400998
"but my question is, why? you are not lighting up the road more, you are just blinding the oncoming traffic more"
Is that the reason why the European car manufactures are using D2S?
Old Apr 19, 2003 | 04:01 PM
rominl's Avatar
rominl
exclusive matchup
nop, it's different housing the eurpean cars they have projective housing, where the beam patterns are different, so you need d2s. but lexus has reflective (except sc430) so you use d2r. with d2s you still shine the same amount of light on the ground, the extra light you shooting them up into the sky
conclevage
May 14, 2010 09:03 AM
LEXISM
Lighting
15
May 24, 2005 03:52 AM
gs300
Lighting
Apr 8, 2005 01:36 PM
retrodrive
Lighting
Mar 6, 2003 10:10 AM
