Sponsored by: CARiD
how do i make these come on(lights)
Old Jan 26, 2003 | 06:08 PM
shoyu's Avatar
shoyu
Banned
Default how do i make these come on(lights)
how do i make these lights come on all the time. i know it involves relays and stuff. and no its not rice... is it? and oh yeah i still cant get into my tailights spent another 3 hours on it and can someone tell me what the hot water trick is i sill dont know
these lights......
Attached Thumbnails how do i make these come on(lights)-_94_sc400_burgundy.jpg
Old Jan 26, 2003 | 06:18 PM
xBlkGs430x's Avatar
xBlkGs430x
im not too sure about the lights, but i can help you with the tail lights
there are little screws that you have to take off and then put it in the oven for about 8minutes at 200dgrs, and it should pull off easy, but there is about 4-5 scews that have to come off before you can pull it out
Old Jan 29, 2003 | 09:06 PM
Skulinex's Avatar
Skulinex
for the front lights, first need to ask, do you want the high beams to come on? or you want the look of the 97 with its DRL in the highbeams? the blinkers is really easy, if you look at the socket you will find on the rear of it an open space where a wire should be on both sides.. simple slide a wire in place of the same gauge as the other ones and your blinkers will come on with the parking lights, you dont have to do anything to the bulb or so because the car already comes with a 1157 bulb... for info on this mod and some help you might want to check this links..
https://www.clublexus.com/forums/sho...ight=1157+bulb
https://www.clublexus.com/forums/sho...rnering+lights
Downtuned
Jun 16, 2024 09:19 AM
kennyw418
Jan 29, 2015 02:08 PM
Cutdogg87
Sep 25, 2013 05:08 PM
Lyrical
Jan 12, 2005 01:26 AM
Legends6spd
Sep 1, 2002 03:25 PM
