Sponsored by: CARiD
headlight/fog bulb sizes, wattages
Old Jan 11, 2003 | 11:51 PM
kylesc400's Avatar
kylesc400
Default headlight/fog bulb sizes, wattages
what are the fitment sizes/wattages for our sc's? im looking for the wattage and fitment (9005, 9006, etc) for 1) the low beam 2) the bulb right next to the low beam (NOT the high beam, but the one thats in the same housing as the regular low beam), 3) 1996 fog lights.
what im planning on doing is changing out all 4 beam bulbs to hyperwhites and my fog lights to a rich yellow, like ive seen some of cl's gs members do. from what ive found from searching, the fog light is 55 watts and the regular low beam is 9006. i have no idea about that beam thats in between the turn signal and the low beam, but im hoping to get a bulb that matches the 9006 hyperwhite i want to put in place of my low beams. if anybody has this info id love to have it
Old Jan 12, 2003 | 01:41 AM
LexAnt's Avatar
LexAnt
that small light is the parking light which is only about 5w... i changed mine's to a LED i found on nextcollection.com The wattage on the 9006 is about 51 or so wattage.
Old Jan 12, 2003 | 01:52 AM
kylesc400's Avatar
kylesc400
anybody know the threshold for the wattage for each bulb? like how low/high can i go with each bulb, and if anybody knows if theres any way to change out that parking bulb please let me now
Old Jan 12, 2003 | 02:05 AM
Taka's Avatar
Taka
they are called "parking light", "city light" and/or "wedge light". so you can seach using them.
I have Raybrig 5w but I just order $4-5 OptiBlue brand one from online. (they are rated 8w and I'm not sure if I'll have any problems). I'll see if I like them or not. otherwise I'll put them in my license plate light
Old Jan 12, 2003 | 06:32 AM
LexAnt's Avatar
LexAnt
i don't kno the threshold but for the head lights i'm runnin piaa's Xtreme white plus 51W=115W and for the fog lights piaa's super plasma 55W=85w and they seem to run fine no poppin or anything
Old Jan 12, 2003 | 06:54 PM
kylesc400's Avatar
kylesc400
just ordered a set of the piaa x-treme super white plus 9006 and 9005. now im wondering is does anybody know exactly what size the parking lights are so i can see if i can find a bright white bulb for that to match my new low/high beams? also, while doing this, i noticed that my fog lights don't come on at all. im not sure if theres a special button/**** to turn for them or what? i dont know if theyve ever come on or not (had the car since june), so i dont know if both bulbs burned out or the wiring is messed up. the fog lights are supposed to come on when you twist the **** toward the front of the car to turn on your parking lights and/or low beams, right?
Old Jan 12, 2003 | 08:17 PM
Taka's Avatar
Taka
parking lights = 168 (or 194) type bulbs? need to varify with others, I forgot exact number.
update:
I assume you have 96 SC, http://www.sylvania.com/bin/carApp/c...400&x=33&y=14, hope this helps...
other links:
http://www.autobulbdepot.com/fr_prod...41855251562778
http://www.piaa.com/wedgebulbs.html#bw2
http://www.jkwebdesign.co.uk/lexuscl...lightthing.htm (uk site)
Old Jan 12, 2003 | 09:52 PM
kylesc400's Avatar
kylesc400
wow great info, thanks a lot
Old Jan 12, 2003 | 09:56 PM
LexAnt's Avatar
LexAnt
yea there's a **** that turns on the fog lights, it's right next to where you turn on the head lights... it's like a little version of the head light switch. I made the big mistake of accidentally turning these off and ended up thinking my fog lights went out when they didn't. Ended up buyin another pair and found out they weren't popped
Old Jan 12, 2003 | 10:02 PM
kylesc400's Avatar
kylesc400
ah *whew*, just a moment of newbism there thanks for the info, ill mess around with that tomorrow morning in fact, assuming they work, im thinking of ordering some of the H3 bulbs in either a bright yellow (like corvettes), or a matching super white like the piaa x-treme white plus's i bought for my high/low beams. any suggestions as to which may look better?
Update: it seems that our fog lights are 55W. would using 70W in these damage the harness or cause any other problems?
Old Jan 13, 2003 | 07:36 PM
kylesc400's Avatar
kylesc400
anybody know if using a 70W or stronger bulb (H3) for our fog lights would cause any damage? melted wire harnesses etc?
Old Jan 13, 2003 | 10:46 PM
EmeraldLexuSC3's Avatar
EmeraldLexuSC3
Post
One of the better brands of lighting products you should consider are Philips ‘Bluevision’ bulbs.
Considerations:
'Bluevision' are rated closely to the Sylvania's ‘SilverStars’ in colour(White) and lighting output. (4100 deg.K) Which have better output to even the higher PIAA wattage bulbs.
Philips has bulbs for all your lighting applications;
9005, 9006, H3 and 168.
They have the parking sidelights; 5W/168 bulbs, which match exactly with the 9005/9006 in colour.
Blue Vision replicates the HID High Intensity Gas Discharge System.
Characteristics: blue multi-layer, filled with halogen and xenon gas, thinner filaments.
Footnote:
I have the Philip 'Bluevision' setup for my Front end lighting requirement and could not be happier, less a HID setup
Check it out:
http://www.powerbulbs.com/index.htm
choirgeek
Lighting
12
Jan 1, 2006 10:23 AM
cc91222
Lighting
Dec 18, 2005 12:09 AM
Canyonero
Lighting
Dec 1, 2004 02:48 AM
Erick G
Lighting
Sep 13, 2002 09:31 PM
