Sponsored by: CARiD
HID foglights
Old Oct 5, 2010 | 06:48 AM
exmeaguy's Avatar
exmeaguy
Default HID foglights
I'm thinking of installing HIDs for my foglights in my 07 RX350. Has anyone done this and if so, do you get a bulb out indicator due to dropping the wattage output from 55 to 35?
Thanks
Old Oct 5, 2010 | 09:27 AM
redrocks's Avatar
redrocks
I replaced foglights with HIDs on my GX470, no problems. Don't believe this will be an issue on the RX.
Old Oct 5, 2010 | 10:13 AM
LZMF1's Avatar
LZMF1
lol, i installed HIDs in all lights and the only ones i've had problems with have been the fog lamps!
a couple of months ago i noticed the passenger side fog lamp was out. initially i thought it was the ballast. i troubleshot it and it turned out to be the bulb. i ordered replacement bulbs from HIDeXtra and they worked flawlessly up until today!!! i went out earlier and noticed that the driver side fog lamp is out and i'm assuming it is the bulb again!
i'm considering getting LEDs that will go in the fog light housing. this is getting annoying.
Old Oct 5, 2010 | 02:01 PM
redrocks's Avatar
redrocks
LZ!!! What going on, man! Now you got me worried about my HIDs on the fog and low beams. Well, time will tell.
Old Oct 5, 2010 | 07:10 PM
Booyah's Avatar
Booyah
My HID fog kit is on the way from Xenon Depot--I have the low beam kit with zero issues so I see no problem with the fog kit?
Old Oct 5, 2010 | 08:11 PM
LZMF1's Avatar
LZMF1
Unhappy
don't know what to tell ya. it seems like my luck has run out lately. for now i just shut them off but i will be looking to get new H3 bulbs for the fogs. possibly HID, LED, or CREE. i dunno. we'll see
Old Oct 6, 2010 | 03:22 PM
redrocks's Avatar
redrocks
That's sucks because you made the cut/mod in the fog light housing to get the wiring in.
Old Oct 10, 2010 | 01:02 AM
Fattyboy21's Avatar
Fattyboy21
Default HID Forg lights
Hi All,
Just to check did anyone change their Fog lights to HID?
Best Regards
Fattyboy21
Old Oct 18, 2010 | 06:08 PM
LZMF1's Avatar
LZMF1
Originally Posted by Fattyboy21
Hi All,
Best Regards
Fattyboy21
check post #3 in this thread.
Old Oct 18, 2010 | 07:09 PM
rselby's Avatar
rselby
I have put some HID 9006 in my fog lights on my 07 is350...no problems at all...all plug n play..hid extra, bulbs n ballast 6k
Old Nov 5, 2010 | 04:45 PM
ldc's Avatar
ldc
I'm waiting for mine, did you disconnect the battery to do the fog conversion?
Old Nov 5, 2010 | 05:13 PM
exmeaguy's Avatar
exmeaguy
You don't have to disconnect the battery. The HIDs just plug into the existing light socket through the connectors that are attached.
Old Nov 5, 2010 | 05:31 PM
ldc's Avatar
ldc
Hmmm but doing the low beams it was suggested to disconnect the battery first? The only diffferent to doing the fog is the bulb type.
Old Nov 15, 2010 | 07:52 PM
rselby's Avatar
rselby
ldc Quote:
I'm waiting for mine, did you disconnect the battery to do the fog conversion? no I did not disconnect the battery...made sure I had the lights off...was all plug n play very easy once u got to the OEM fog light
Old Nov 15, 2010 | 08:03 PM
exmeaguy's Avatar
exmeaguy
I finally installed 5K HID fog lights and they look great and noticeably add a lot more light onto the road. For the left side, I had to remove the battery so I had room to reach down and install the light and the ballast. For the right side, I had to remove the cover panel but there is less room to work with than the left side.
Now I need to change my low beams to either 5K or 6K. I have 6K HIDs on my other car and the light is much better to see reflective road paint than the OEM 4300s.
I recommend that everyone should do this change.
