Sponsored by: CARiD
95 es300 output difference
Old Aug 17, 2009 | 08:09 PM
arnshrty's Avatar
arnshrty
Exclamation Headlight output different 95 es300
Alright I've change all my bulbs and cleaned my lenses, no yellowing or oxidation, what could be causing my passenger side headlight to have a lower intensity/output than the drivers side? Could the projector be dirty or a wiring problem? By the way they are the stock projectors no mods whatsoever.
Old Aug 25, 2009 | 07:47 PM
arnshrty's Avatar
arnshrty
any help guys?
Old Aug 25, 2009 | 07:48 PM
4rings's Avatar
4rings
it could be the projector on the inside where the light reflects on the chrome bowl is peeling..,, i would just retrofit some nice TL projectors in them.. it would give you a much better output.
Old Aug 25, 2009 | 07:52 PM
4rings's Avatar
4rings
the only way you can tell is to take your headlights apart or just buy new headlights to solve your problem.
here is a new set on Ebay http://cgi.ebay.com/ebaymotors/LEXUS...=p4506.c0.m245
Old Sep 3, 2009 | 02:25 PM
swifty562's Avatar
swifty562
check your fuse... see if the passenger side has the same fuse as the drive side.
Old Sep 3, 2009 | 08:44 PM
eyezack87's Avatar
eyezack87
Projector bulb is most likely the thing affecting the output. Heres mine before and after I cleaned the lens. Excuse the business card, I did this ages ago, before we had problems on CL
Old Sep 3, 2009 | 09:15 PM
arnshrty's Avatar
arnshrty
Thanks for all the info guys...i'll let you know what fixed it.
Old Sep 3, 2009 | 11:53 PM
swifty562's Avatar
swifty562
that could be it also ^..
i guess that micro fiber and some solutions got that shinny!
Old Sep 5, 2009 | 03:27 AM
SickES350's Avatar
SickES350
make sure the bulbs are in correctly? i remember when i put in my bulbs, there's this funky little bracket that goes in too, it was positioned correctly, so my bulb on one side didnt sit quite right, which caused one side to be significantly dimmer.
rclab1
Sep 22, 2010 05:11 AM
sbristow84
Apr 23, 2010 05:23 PM
acc
Mar 15, 2009 03:46 PM
dante1616
Dec 23, 2007 10:28 PM
