Sponsored by: CARiD
RX Headlight Comparo - Needs you!
Old Mar 15, 2002 | 01:23 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Default RX Headlight Comparo - Needs you!
I want to do a comparison of the RX headlight lenses to see if there is a difference between the HID and non-HID reflector housing. There has been a lot of talk on CL lately about upgrading to HID and that the look won't be the same w/o OEM parts, I want to see first-hand if there is a difference.
IMO, if a Lexus has an aftermarket HID kit, the beam pattern should be the same if the reflector housing is the same and a D2R bulb is used.
So, let me start by taking a pic of my '00 RX's low-beam lens housing. We can see if there is a difference b/t that and the '01+ non-hid and '01+ w/ HID.
-Nick
Old Mar 15, 2002 | 01:24 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Here are two: First is the RX picture taken w/o a flash and the second one with a flash.
Old Mar 15, 2002 | 01:26 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Default w/ flash
Old Mar 15, 2002 | 01:27 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
This is a '99 LS with HID. The basic design of the lens is very similar to the above pictures.
Old Mar 15, 2002 | 03:45 PM
hleo1's Avatar
hleo1
Nick,
I'm sure the beam pattern will be same IF your aftermarket HID bulb is also using D2R. Most aftermarket HID use D2S bulbs, so for your comparison, make sure you have D2R 9006 HID kit.
As for illumination brightness, I think the aftermarket will be brighter than oem. I think federal regulations set limit for brightness, so IMO as bright as the oem HID, it won't be as bright as the aftermarket. That's why if you notice, all aftermarket HID kits show "For Off-Road Only"...
-Hendry
Old Mar 15, 2002 | 04:29 PM
wwest's Avatar
wwest
Default HID
Aftermarket HID upgrades.
The OEM versions are "legal" becuase they incorporate auto-leveling, required becuase DOT ruled they would be too high, bright, if "leveling" was not auto-controlled.
So your aftermarket HIDs are actually more likely to be less bright than the OEM versions.
Old Mar 15, 2002 | 05:17 PM
hleo1's Avatar
hleo1
Uurrr... sorry... have to disagree with you about that...
I've personally witnessed the Lexus GS with oem HID and aftermarket HID... and seems to me the aftermarket projects more "light" on the road...
that's my 2 cents... you may disagree ...
Old Mar 15, 2002 | 05:48 PM
01VaporBlueRX's Avatar
01VaporBlueRX
Hey Nick
When we were at the dealer picking out our car, I was comparing the housing of the xenons to the halogens, and noticed that the xenons have those vertical bars in your pic all the way across, while the halogens dont just like in your picture. Donno if what im typing makes sense, so tell me if u dont understand....
Old Mar 15, 2002 | 09:18 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
wwest, it sounds as if you are saying that by putting auto-leveling on an HID equipped vehicle the lighting is not as bright. They aren't going to be too high if they are aimed properly just like halogens. Also, you will not find auto-leveling all HID equipped vehicles, take Acura for example.
Auto-leveling reduces glare when there is a load in the rear of an HID equipped vehicle, it also gives the driver an accurate illumination point. So, yes, I disagree too
01VaporBlueRX (I hate that I can't remember you're actual name - I'm bad at that ), I think I do know what you are talking about. I have noticed how OEM HID's don't fill the bottom portion of the light housing when on. I looked closely at our LS and could see the shield on the D2R bulb. I will definantly go with that if (WHEN) I get the kit. I just have to sell my dahm steering wheel and airbag
Okay, I've started rambling...yeah, I think I know what you mean. It's the vertical bars marked below right?
Old Mar 15, 2002 | 09:22 PM
01VaporBlueRX
Yeah Nick those were the bars I was talking bout. Its alrite if u dont remember my name, i always froget to put my name at the end of the posts, so it's Paul.
-Paul
Old Mar 16, 2002 | 08:49 PM
MrSypher's Avatar
MrSypher
Hey Paul, what's the Happs???
waxman
Feb 6, 2017 04:08 PM
franbev
Nov 15, 2016 11:50 AM
wing0
RX - 1st Gen (1999-2003)
Apr 9, 2016 03:45 PM
Supraristo
Lighting
Jul 25, 2006 12:31 AM
