Sponsored by: CARiD
Will only phillips d2r bulbs fit in a gs harness?
Old Dec 12, 2007 | 11:18 PM
infa_red's Avatar
infa_red
Default Will only phillips d2r bulbs fit in a gs harness?
i have a 01 gs430 i had purchased some aftermarket 6000k d2r bulbs from a guy but when i put them in the harness they wouldnt click into it and lock plz advise
thanks
Old Dec 13, 2007 | 01:04 AM
GSteg's Avatar
GSteg
Are you sure the bulb connector is turned the right way? the D2R and D2S lock in the same way.
Old Dec 13, 2007 | 01:49 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
you DO have factory HID right....
otherwise yea, any D2-style bulb will fit.
Old Dec 13, 2007 | 05:14 AM
DarKnight's Avatar
DarKnight
Unless his headlights were swapped out, all GS430's came with HID from factory. It should work, even a D2S bulb should work. Make sure it has the two prongs sticking out on opposite sides.
Old Dec 13, 2007 | 08:55 AM
rominl's Avatar
rominl
exclusive matchup
correct, HID is standard on all gs430
if it's d2r, it should fit
d2s, it will not fit. not unless you use dremel to create a **** on the opposite side. the **** location helps determine if it's d2s or d2r (officially. some aftermarket companies they just have the ***** on both sides)
Old Dec 13, 2007 | 08:59 AM
emoshun's Avatar
emoshun
thanks
Read This
http://faqlight.carpassion.info/hl-hid-bulbs.htm
This is why it won't work, I hope this helps.
Old Dec 13, 2007 | 10:02 AM
emoshun's Avatar
emoshun
BTW;
The Philip's bulb you want to buy would be the 85126+.
http://cgi.ebay.com/ebaymotors/2-PHI...spagenameZWDVW
Old Dec 13, 2007 | 12:20 PM
GSteg's Avatar
GSteg
The actual harness (connector) locks in the same way whether its d2s or d2r. What wont fit is the base to the housing. But nothing a little dremeling work can't fix
Old Dec 13, 2007 | 12:34 PM
DarKnight's Avatar
DarKnight
I've put both D2S and D2R bulbs in my projectors with no problems or modifications.
Old Dec 13, 2007 | 08:39 PM
infa_red's Avatar
infa_red
and it wasnt phillips? what the hell why wont these work then? i must be doing something wrong manb
Old Dec 13, 2007 | 08:52 PM
DarKnight's Avatar
DarKnight
I don't know if it's different on HID reflector bowls as I have never had them.
Old Jan 8, 2008 | 07:02 PM
infa_red's Avatar
infa_red
im going to take a pic of the bulb so u guys can see it
Old Jan 8, 2008 | 07:55 PM
rominl's Avatar
rominl
exclusive matchup
take a pic and we will go from there
Old Jan 8, 2008 | 11:46 PM
emoshun's Avatar
emoshun
Originally Posted by emoshun
Just tell us left or right. C'mon guy!
Old Jan 10, 2008 | 11:08 AM
truman363's Avatar
truman363
I also have a blown headlight on a 99 GS400 and I need a 4300k HID bulb. I dont want to pay $300 buying it from the dealer so I want to go with a Phillips bulb from XenonDepot.com but I want to replace it before the weekend. Is there any autoparts store I can buy one or is ordering them online the best option?
